Results 1 to 16 of 16
    Jun 2009
    Midlands
    19
    Where i can locate a good engine for an A4 2.5 TDi Quattro 180 BHP (AKE)
    Can anyone help with the location of a good Audi 2.5 Tdi AKE engine.. i've spoken to Sanburn and theyre fully out of stock and reckon that this is not an easy piece of kit to locate..
    Any suggestions would be most welcome...
    The reasons for my need is as follows from a separate thread:
    The cam under cylinder 4 is well worn and as such the valve is not opening properly (Pressure blowing the wrong way).
    The cam under cylinder 2 is also very well worn and has caused the rockers to jump out of position and snap two followers. (like you diagonosed Adam)
    There's also a hairline crack around one of the injectors..
    All in all the prices i';m getting for Cams / followers and hydrolic's is around the £1,200 mark without labour ...
    The car's going in for a 2nd opinion tomorrow but, I've got tears in my ears..
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I struggled to find one for mine, and it cost me £1500 plus vat.
    If I had my time again I'd rather spend the money on my existing engine as it's a known quantity.
    Jun 2009
    Midlands
    19
    Cheers James, was that price including fitting.. ?
    When you say, if you did it again you'd spend the money on your existing one, why is that..?? is this one lacking in some way ?
    Mar 2008
    Dorset
    13,856
    Long story VERY short .....
    Timing belt skipped 4 teeth and garage advised probably cheaper to source a replacement engine as followers were broken and gone down oilways etc, so I found one for £1.5k plus vat, which was sold to me as a replacement rather than a recon, but that had been fully checked over and any worn bits replaced. Then £1k to fit at my local garage. Six days after I get the car back and BANG, no. 2 engine self destructs. So it goes back to engine supplier who have the car 6 weeks and 'replace' the engine (a bolt on the tensioner pulley had broken). So the car now stands me at just under £3k.
    I get the car back and it's running like a bag of bolts. In addition 3 or my 4 new wheels are damaged, oil on the seats etc etc so I refuse to use the original supplier (not my local garage who were brilliant) so it goes off to a local VAG specialist. They diagnose the need for a couple of new injectors and the needle valve and say that in their opinion the timing gear on the engine is not new ....... so I bite the bullet and commission the work which hits me for a further £1.5k - so the total nightmare cost me £4.5k to resolve.
    In hindsight ..... my local garage could have totally rebuilt my existing engine for a LOT less than that and I would have an engine I knew the history of, whereas now I have no idea about my engine. That said, this was 3 years ago and the car has been ok since (touch wood).
    Moral of the story is don't buy an engine from an unknown supplier at the other side of the country.
    Jan 2006
    UK, Blackpool
    100
    I agree...it might be better, in the long term, and looking at the bigger (financial) picture, to spend £3000 on a full engine rebuild of your existing engine than go the replacement route at maybe £1500 plus £1000 fitted, but not your engine!!
    Better the devil you know!
    Jun 2009
    Midlands
    19
    Bloody Hell mate, that story was worthy of a hammer house of horror full feature..
    The things that you went through are the things that I'm most worried about happening if I had to go out and buy an unknown second hand engine.
    I think i agree with you completely that the best way sensibly to attack this will be be to have my engine repaired / rebuilt and bite the bullet with the labour costs etc ..
    Thanks for the insight mate. i really appreciate it ..
    Mar 2008
    Dorset
    13,856
    No problem, good luck!
    V6 Quatt's Avatar
    Feb 2008
    783
    Sorry to here your story Quattro James -Luckily i have owned 2 x 2.5TDI Q Sports and both of them seemed great got the last one up to 137k miles and seemed strong..but you never know hey. Was going to get another but not sure now. Seanr Good luck mate. Hopefully Steve can sort it.
    Torque the Torque
    Mar 2008
    Dorset
    13,856
    They're good engines. Prior to my ownership at the 80k timing belt change they "checked" the pulleys but didn't replace them .....
    Jul 2007
    London
    3,247
    I have a 2 good running enginse 1 is in my allroad, the other in my a4 quattro. Both can be driven prior removal. They are both AKE code, with all belts replaced last summer and allways fed synthetic oil at 6k miles. I am swapping a souped-up 1.9 Tdi engine wich should be ok with the weight of the car (I hope !)... I can even fit it for you if you give me a few days, i am based in N. london. regards, Chris- 077 899 12128.
    FOR SALE:
    Jun 2009
    Midlands
    19
    will call you know mate...!!!!
    Jul 2007
    London
    3,247
    Here's a few pictures of the car mate, just to let you know that i don't neglect my car in any way, shape or form ! Had the motor for a few good years and it's been a slow moddifying process...
    FOR SALE:
    Jun 2009
    Midlands
    19
    Thanks for the photo's Chris.. Just out of curiosity.
    What is the modifying history of this car to date.. and how far are you going to take it.. ??
    also, I will private mail you to find out some more info on the engine...
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    Quote Originally Posted by adamss24 View Post
    Good on ya mate,
    Jul 2007
    London
    3,247
    Little clip made with crappy camera phone on the private road leading to local trading estate this is a FWD 1.9 tdi formerly 90 Bhp which i bought with a damaged engine, think it should do ok in the b5, the car is still running the stock map. Click the picture should take you to the link :
    FOR SALE:
    Jul 2007
    London
    3,247
    Ignore the interior picture, that's not from the a4 is actually from a old b5 passat estate !
    FOR SALE:
