Badger5Volks Autos
    TURBOTRONICS's Avatar
    Jun 2009
    186
    any one tell me what this means
    vcds
    4 Faults Found:
    17983 - Right Engine Mount Solenoid Valve (N145): Short to Plus
    P1575 - 001 - Upper Limit Exceeded
    16540 - Oxygen (Lambda) Sensor B2 S2: Malfunction in Circuit
    P0156 - 008 - Implausible Signal - Intermittent
    16440 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit: Malfunction / Open Circuit
    P0056 - 004 - No Signal/Communication - MIL ON
    17548 - Oxygen (Lambda) Sensor; B2 S2: Internal Resistance too High
    P1140 - 004 - No Signal/Communication - MIL ON
    Readiness: 0000 0000
    dsmclark40v's Avatar
    Sep 2006
    Hampshire
    715
    Sounds to me like you need a new engine mount, have a look to see if ones leaked as they have fluid in them. You can just change the one but if the old one has gone soft it won't last long with the new one so you will be better of changing them both.
    And the other codes are for lambda sensor. It's the drivers side rear sensor before the main cat
    Sam,
    Gone
    Jun 2009
    186
    thanks sam
    any idea on what the engine mounts cost and what sort of a job it is change them
    and how many lambda sensors are on my car
    Sep 2006
    Hampshire
    715
    Not sure how much the oem ones cost. I'm pretty sure B7 rs4 ones fit and would be a chance for upgrade. I know 034 do some uprated one and they cost about $80 each in America.
    Apparently they are quite easy to change as long as you have hoist, just have to do one side at a time. A competent garage shouldn't take much longer than an hour I shouldn't think.
    You've only got one lambda that's gone bad judging by your codes. The car has 4 lambda's, 2 before the pre cats and 2 before the main cats.
    Sam,
    Gone
    Jun 2009
    186
    thanks sam very helpful
