Rhencullen1989
190 S LINE QUATTRO
Hi, need to change my brake/clutch fluid, i have bought a pressure fed bleeding kit so should be straight forward, question is what order do i bleed in, clutch first or last, front left, right, rear left, right?
I used to think you started with the furthest away but have things changed. Also how much fluid should i bleed from each calliper, i was thinking of about a jam jar full?
