Chris NottSky Insurance
    Audi A4 Cab, 2.4 V6 2002,
    Jan 2009
    Sale, Manchester
    22
    Talking Cab roof stuck half way....
    Hi
    I was opening the roof when the car stalled the roof was half open. I restarted the car but the roof would go neither up nor down. Finally rang the wife to read the hand book on lowering the roof manually, found the tool in the fuse box. Lowered the roof and locked shut to drive home.
    When I got home tried opening the roof, closing it but still would not reset the electronics. Located the fuse and removed it, the fuse was not blown. After a couple of minutes replaced the fuse turn the ignition on and off a couple of time and the system restarted and all seems to be working fine now.
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    the are like most things mate, don't like being told to pull out half way through a job!
    Jan 2006
    UK, Blackpool
    100
    Yes, i had this issue once - I had to manually fully open the roof with the key and then manually close it fully, with the key, until the sensors came back in sync. then all was well.
