Sky InsuranceAH Fabrications
Results 1 to 13 of 13
    biyitch's Avatar
    Chocolate? It's doo-doo, baby!
    Southampton
    300
    Rattling Brake Pads
    I've had this horrible noise when going over medium-sized bumps in the S4 recently.
    I had it in the garage on Friday and they could hear the noise but struggled to find the source.
    The only thing they could find was that the nearside front brake pad sits a little loose - but there's nothing wrong with it. No idea what make they are (probably OEM)
    Has anyone had this problem and solved it?
    Audi S4 Avant (B6, 2004) in Goodwood Green.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,285
    I had this on my old S3 8L.
    Noise was really annoying and i traced it back to my rear pads. I had only replaced them recently and was sure they were ok but turns out the pads i bought didnt have the rubber backing that better quality ones had and so rattled against the caliper. You may just need a shim on the outside of the pad to make it fit more snugly and stop it rattling in the caliper.
    i just bought some better quality pads and fitted them et voila noise was gone.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    biyitch's Avatar
    Southampton
    300
    I was tempted to get new pads but even the garage owner said it'd be a waste of money since there's plenty of wear left in them.
    Did you look into the anti-rattle shims before you bought new pads?
    vrbob's Avatar
    Jun 2007
    Southampton
    2,285
    The pads i bought didnt come with shims and there wasnt any on the old ones i took off so i assumed (probably a mistake) that there wasnt any. Now as the rear brakes only do 30% of the actual braking (other than handbrake) i hadnt spent alot on the pads so just binned the crap ones and spent £30 on some mintex ones (good brand cheap prices) they had rubber on the backs off the pads and were a better fit so just swapped them over and problem solved (without any shims).
    If you can get some new shims you can try that first and see if your problem is sloved if not then maybe some new pads will be in order. Just have a look at them before you purchase to see what they have on the backs and compare to the ones your taking off.
    Apr 2011
    160
    Why not try going over bumps with the break just on so its not really slowing you down but the slacks been taken up, that would surely give you some idea if the brake pads are loose. Just an idea
    biyitch's Avatar
    Southampton
    300
    Quote Originally Posted by Jama665 View Post
    Yep. That would confirm it alright.
    Apr 2010
    Burnley, near monty carlo !!!
    351
    I've got the same problem just not sure whether its the front or back pads.Will the shim justnot fall out again after a few days, what keeps the shims secure???
    A4 TDI SPORT with full leather and thats it as standard.Fitted by me.Remap,S-LINE BADGES.S4 Wing mirrors.DIS,Seat Cupra splitter.Rear parking sensors.5k hids+LED side lights+DRL lights+chrome indicator bulbs,amber fog lights.LED Xenon number plate bulbs,upper/lower front grills+boot strip in matt black.Ipod dock.19" BMW X5 SPORT CONCAVE ALLOYS,9 J FRONT 10 J REAR 20mm hub adapters front ET 28,18mm hub adapters rear ET 27.
    TO DO.B5 spring perches.Renault rear diffuser?? S/S exhaust.
    biyitch's Avatar
    Southampton
    300
    No idea. I think I had them on an old car but I can't recall.
    biyitch's Avatar
    Southampton
    300
    I tried it a couple of times this afternoon and it didn't make a sound when I braked (hard to be certain the bumps were severe enough to have caused it though).
    Apr 2011
    160
    Ha Ha thats the thing with all these types of problems. You'l have to find one that does then go back round lol. I hate rattles on cars so spent lots a time trial testing all sorts things to find where they come from.
    defsix's Avatar
    149
    Take out the breakpads and sit them in a bed of copper grease when you put them pack in. When washing the car with a power washer avoid washing the area where the pads are.
    AUDI A4 Avant 1.9TDi Sport
    | RS4 RARB - RS6 18" - SLCR Spolier - HID's / Laminex / DRL's - Ext LED lighting - Ambient Lighting F+R - Dension300 / iPod Touch - Siemens Bluetooth - DIS - Cruise|
    biyitch's Avatar
    Southampton
    300
    Quote Originally Posted by defsix View Post
    What does that do?
    I don't use a pressure washer but, when I do wash the car, I usually don't use it until the next day, at which point the wheels 'stick' as I reverse from my space.
    Apr 2010
    351
    Will this stop the rattles??? + are you meant to only put one side of the pad in or full dip it in grease???????
