Monster MotorsportVolks Autos
Thread: will it fit?
    Jun 2011
    213
    will it fit?
    hello all am i right in thinking that 3.0 and s4 exhausts are the same from the cat back?
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    not to sure, if yours is a 4 wheel drive then the rear section from where it splits should be the same
    Apr 2010
    529
    I've just fitted a s4 exhaust to my 2.5tdi v6. Had to shorten the length of the pipes slightly and also shorten the distance between the pipes that connect to the cats by 20mm.
    Jun 2011
    213
    cheers people yes mine is quattro so i think should be same unless anyone else knows otherwise
