the below is a great guide posted by pj123 which i also used to clean the drain holes under the battery.
if i can do it, anyone can......
"It really is an easy DIY fix, will take you about an hour max.
- under the bonnet remove the plastic cover across the top of the battery by removing the rubber strip that runs the full width of the car. Just pulls off.
- Disconnect the negative lead on the battery then the positive which has two nuts to undo.
- The battery is secure on the front side of the battery at the base with a allen key head. A long allen key is required for this.
- Lift the battery out
- Two nuts secure the battery support bracket. Below this is the first grommet (cam shaped rubber thing) which just pulls out.
- From memory you can then reach across to the drivers side below the brake servo (big round black thing) to get to the other grommet. There will probably be a cable/ wire running through the grommet itself. I just pushed the grommet through the hole and left it connected to the cable but you could cut the grommet free.
Reverse order to replace and always replace positive first then negative second.
I think you have a couple of hours of the battery being disconnected before you will need the radio code.
To make the key work again, put it into the ignition, turn to position 2 and press unlock and lock together.
The traction control light will be on after replacing the battery and starting the engine. This will go out when you start driving".
