sorry for the late reply, i gave the car a clean yesterday and found the wires under the plastic cover, so it is deffo safe to remove them with no key in the ignition? cant be ***** with a dozen airbags going off lol!
make sure you got the right yellow connector though. its not usually the ones on the floor its the ones up under the seat. i found it easier by going under the seat from the rear. i just pushed them together tightly. and reset with vag com and voila!
I had the same problem, kept pushing them together, even sello taped them together just so that they are tight but no joy. I ended up cutting the connectors off and soldering the wires from the seat directly to the wires in the floor
