Volks AutosSky Insurance
Results 1 to 20 of 20
    Feb 2011
    Air Conditioning
    Car just had a re-gas at Audi Wimbledon but advised needs new unit/compressor. They suggest £850.00 just for the part!!! Any suggestions as with the current weather the car is unbearable.
    iyrix's Avatar
    Mar 2010
    427
    Is it cold after the regas?
    Audi A4 TDi 130 Sport
    Feb 2011
    No it made absolutely no difference
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    The part is expensive, you could fit a used part for a lot cheaper. ebay may offer a bargain. audi prices are always high. failing that open your window
    Avant4me's Avatar
    The're Graphite not black!!
    Mar 2010
    Bristol
    257
    Get it on VAG come first. Very common fault is the hight pressure sensor which is to the right of the cooler when looking at the front of the car. Does the ECON light go out??
    Official Fan Club member No 001!!
    May 2010
    London
    84
    If you do need the part check out if their are some non OEM ones. I had one go on my previous Seat Toledo and due to the cost of the car Seat themselves got a non-OEM one in for me at half the price, otherwise the charge would have been very similar to what they are asking you.
    Jun 2003
    World of my own
    9,813
    And don't let Audi near it, they know nothing about aircon, they'll just replace ludicrously priced parts until the problem goes away. Audi don't make any of the components for the A/C so take it to an aircon specialist. Should be about £400 fitted at a specialist, but as said I wouldn't trust Audi's diagnosis at all.
    Does the ac fan spin? This is a common failure and a very easy fix
    Alex Turner
    Apr 2004
    London
    404
    I've just been quoted £1900 by Audi to replace the compressor and flush the system. Awaiting a quote from an A/C specialist instead.
    Aug 2009
    Durham
    110
    went to get my aircon regased at a local indy and it didnt work they pressure tested but there was no leak,so he went to use vagcom and tryed get the ac fan to work through vagcom and it still wont work.I've had to book it in again so he can do more checks as he was closing and didnt have time to do it.Do any of you guys no what other things it could be thats causing the air con not to work?
    Jun 2011
    245
    just repaired mine ,the eco light wouldn't go out so wouldn't fire up the fans or compressor , read on the net it need re-gasing as low pressure would stop it working so had it done but still no joy ,so booked it into a local specialists and he tested and found pressure switch faulty but couldn't locate it LOL, so i went on net and found it is located on the side of the air-con rad at the side of the passenger headlights , rang audi and they had one in stock @ £52.88 so got it and fitted it ,i have nice ice cold air-con now
    dubstar74's Avatar
    Jan 2011
    S.E.London
    88
    I had my B6 Tdi re-gassed at my local garage £45 for test, empty old oil, and refill with new oil, now its ICE cold!!! I'am a happy chappy )
    Ich liebe Deutsch autos
    simon.m's Avatar
    Oct 2009
    2,746
    rub it in why not lol
    Oct 2009
    Kent
    314
    Quote Originally Posted by simon.m View Post
    Bloody hell Simon is your aircon still not working, i've just had mine re-gassed and is ice cold but when i had my mot done on friday they noticed it was leaking from the nut on the metal pipe that goes into the rad i hope that this will be easy to fix as i've just been robbed by the government for the £245 road tax aaaarrrrrrrrrrrrrrrrrggggggghhhhhhhhhh.
    Jay
    audigeezA4's Avatar
    Mar 2011
    104
    so are you guys all saying that if it aint "ice cold" then its not working properly? mine blows out quite cool air but i wouldn't call it cold cold, if that makes any sense, so should i be looking at an obvious service/ re-gas?
    Oct 2009
    Kent
    314
    Audigeez,
    My aircon just was'nt cold when i started using it this year so just had it re-gassed but now i know why it stopped working its cos its got a leak but hopefully not an expensive fix just a nut that needs tweeking up
    Jay
    audigeezA4's Avatar
    Mar 2011
    104
    Quote Originally Posted by jolly14 View Post
    Audigeez,
    Jay
    ah right fella- well at least you know why you were just blowing out hot air....
    i hope you fix it pal, at least its better than a £800 bill...ouch....
    simon.m's Avatar
    Oct 2009
    2,746
    yeah still not done mine mate will need to get a new compressor ;-( should be getting my car back to day after nearly 4 weeks ;-)
    mikeh126's Avatar
    Preston, UK
    152
    Quote Originally Posted by audigeezA4 View Post
    It should be blowing ice cold air. If it's not, it's blowing air at outside temp - equivalent of pushing the 'econ' button. So, I would say, it needs a service / re-gas.
    2003 A4 Avant 2.5TDi 180 Quattro Sport in Light Metallic Silver, Remapped to 220 by ProTec Motorsport, RS4 18" x 8J reps, Falken F452 tyres, 10mm H+R Spacers, Matt Aluminium Mirror Covers, Heated Mirrors, S4 Door Blades, Continental TS830p Winter Tyres on 5 star 17" Sport Alloys
    Oct 2009
    Kent
    314
    Why have you not had your car for 4 weeks mate.
    Jay
    audigeezA4's Avatar
    Mar 2011
    104
    Quote Originally Posted by mikeh126 View Post
    yeah i thought as much, plus it smells a little bit too so will try some odour treatment at the same time.
    cheers pal.
