Sky InsuranceVolks Autos
Results 1 to 8 of 8
    mitch2575's Avatar
    Oct 2010
    112
    Help with Sounds
    Hey All,
    Does anyone Know if (I Think) its the Symphony 2 stereo has any RCA connections to wire up to a amp, i have the Bose setup, but want to hook another amp and subs which sits nicely under my roof box of my Cab??
    Anyone in the Warwickshire area can help me install as i'm not very good with this stuff?? (will throw in some choccie Biccies/or something stronger for assitance in setting up)
    Mitch
    1.8T Quattro Sport - Stock at present!
    Wish List - Remap, Sounds, AIR RIDE! & Shoes!
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    946
    No RCA comnnectors as uses a bespoke Audi connector for CD-Changer/Amp Pre-out etc.
    You can get adaptors to change the pre-amp Audi connections to RCA connections and this would be in place of your BOSE.
    This document has all the relevant pin out connections for the Symphony II and RNS-E
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Jun 2003
    World of my own
    9,813
    That doc is for Quadlock, you will have ISO connectors
    Alex Turner
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    Quote Originally Posted by AndyMac View Post
    Look again - On page 1 it has Quadlock on the left column under "RNS-E" and ISO connectors on the right under "Symphony II" column. On page 2 it shows the various Quadlock connectors labelled A/B/C/D and ISO type connectors labelled I/II/III/IV.
    It is however listed in favour of the Quadlock, i.e. sorted to Quadlock connector A/B/C/D pin order.
    ISO Connector I carries the pre-amp signals, indicated with an '*':
    1=*Left Rear out
    2=*Right Rear out
    3=*common
    4=*Left Front out
    5=*Rear Front out
    6=*Amp turn on
    7=CAN-H
    8=nc
    9=nc
    10=CD Ground
    11=nc
    12=CAN-L
    13=CD Data in
    14=CD data out
    15=CD Data clock
    16=+12v
    17=Accessory power
    18=Signal Ground
    19=CD L Channel in
    20=CD R channel in
    Jun 2003
    World of my own
    9,813
    I stand corrected, apologies, useful doc, thanks
    All you really need is the BLAU RCA adapter, which just plugs into the HU and gives you front & rear RCA's and remote on:
    Blaupunkt 4 channel pre-amp out RCA adapter lead
    Alex Turner
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    No worries - that's the type of adaptor required, however this is for a 3 part plug for "Connector I", a factory BOSE plug is usually a complete 20 pin connector that will not break down into the three segments. Using only this adaptor would lose the CAN (headunit would ask for PIN code at power on) and CD connectors for an external changer. On VW Passats I have had you could break the plugs down and reassemble the segments with the parts you wanted to change.
    mitch2575's Avatar
    Oct 2010
    112
    Thanks Fella!! it's more of a ball ache might as well save my pennies for a new HU with RCA connections, If i change the HU can the BOSE system still plug & Play!
    Jun 2003
    World of my own
    9,813
    You can just use a PIE adapter to break the single plug into segments (as long as you don't have a separate changer):
    Audi iPOD MP3 splitter CD changer PIE AA3 HAR adapter | eBay UK
    Aftermarket HU's don't work well with the Bose amp, you can get popping whenever you change track.
    Alex Turner
