Uprated Clutch?
chrisash32
Manchester
Hi Everyone.
Clutch started slipping on my A4 over the weekend.
Its a 1.9TDi running at around 165hp currently with 112k on the clock.
My question is, should i fit an uprated replacement clutch and if so what should I go for?
Secondly, is it usual practice to replace the flywheel at the same time on these?
Thanks!
well with the power your running id stick with oem maybe sachs
you will have to let the mech look at flywheel may not need changeing but at 112k id change it
6 speed clutch is pretty strong and is bigger like 5speed clutch(240mm vs 288mm),can hold more than 400nm torque safe;so stick with oem :icon_thumright:
