JMB RetrofitsSky Insurance
    Oct 2010
    A4 CAB ROOF TROUBLES
    Hi,
    I have an issue with the roof on my 03 A4 cab ! it was working fine and i stupidly shut the car of half way into closing the roof! when i re-started the ignition the roof wouldnt work. I ended up doing a full manual open and close. Now when i try i can get the roof down it works in stages, I have to unlcok using the tool the latches from the front (windscreen) then the button works all the way back to the part before the boot opens, i then use the tool on the front latches again and close them inwards and then the button works all the way till close. this is the same when opening.... not sure if theres a motor section under the plastic in the roof (windscreen side) that may be broke...any ideas welcome..
    thanks
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    there is sensors every where
    you need a full manual reset
    from closed
    car running open with the unlock tool open it fully make sure you lock it in from the back
    then do the same to close is should reset it
Tags for this Thread
