EM TuningAH Fabrications
Results 1 to 22 of 22
Thread: EGR Bypass
    Jul 2010
    184
    EGR Bypass
    Has anyone used a EGR delete kit by Allard or Forge on their PD130?
    Ive disconnected the vac lines to it and the ASV with no problems so want to ditch the whole assembly now.
    Does the transverse kit fit the longitudinal engines?
    Oct 2009
    Hull
    1,442
    just make a plate to go either end of the egr pipe and job done!!
    Avant4me's Avatar
    The're Graphite not black!!
    Mar 2010
    Bristol
    257
    What are the benefits of this, think mine is playing up now.
    Official Fan Club member No 001!!
    Jan 2009
    150
    I bought a plate on ebay, you notice the throttle responce after fitting.
    Jan 2011
    612
    Didn't fancy going down the blanking off route, cleaned mine out this weekend......
    Didn't bother with taking the inlet manifold off, EGR was a bit tricky with the last bolt, but dear God I'm surprised it was even working with 100K of crud inside it....
    engine does seem a little bit more responsive, but that may just be me.......
    03MY 52 reg 1.9 TDi 130PS Quattro Sport Avant - 170bhp remap, RNS-E+OEM bluetooth, B7 wiper arms/blades, 4300K HID+nightbreakers/LED sidelights, rear tints, new lights all round, new front/rear screens, frt armrest, s-line kit, cruise/DIS, B7 gearknob/aluminium trims, parking sensors, black grilles, RS4 RARB, S4 front end, black 18" RS6 alloys
    Still waiting..... S4 rear bumper, exhaust tips, coilovers, leather recaro's.... phew...
    snowball1969's Avatar
    Mission To Mars Champion
    Oct 2010
    Corsham, Wiltshire, United Kingdom
    112
    has anyone got any pix, dummy guide of how to remove EGR and intake to clean
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    ive blanked the EGR on quite a few diesels now
    definately better and a clean intake too
    i know they bleat on about higher nox but the EGR is barely doing anything and quite often nothing at all at full throttle anyway so i dont see the harm,
    my argument is when did it become a good thing to put carbon deposites down the bores of the engine?
    and also block the inlets up Mmmm that makes for efficient engines
    also on efficiency how can putting burnt exhaust gases back in the engine help with the burn
    clean air more oxygen creates a better bang .
    Jul 2010
    184
    I could blank it off but the valve is pretty restrictive, its not in use so i want it binned.
    Just wondered if i could use a 130 kit from a transverse engine?
    Avant4me's Avatar
    Mar 2010
    Bristol
    257
    Does the plate kit not allow you to remove completely. Is there VCDS coding required?
    Jul 2010
    184
    If you fit the plates all you can get rid of is the pipe from the manifold to the EGR valve housing.
    No coding is needed on vag com from what i can see and my own bypass.
    Sep 2010
    stoke on trent
    37
    Hi got allard pipe fitted to 130pd awx with 189000 miles on clock it great no cleaning egr because total removed and no codes also decat and k&n .
    Jul 2010
    184
    Awesome! Just what I wanted to hear. So the 130 one they sell works and fits fine?
    Thanks.
    Sep 2010
    stoke on trent
    37
    yes fit fine no problems. just took the pipes from egr/shudder valve under air box .
    Sep 2010
    498
    I'm also thinking about this as my EGR needs replacing but its much cheaper to install the delete kit and may well improve responsiveness a little. I heard that this could cause problems with MOT's and also has anyone gotten any engine management lights come on?
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    I installed a blanking plate to mine a couple of days ago and its actually in for mot today so will update as to the emissions test results when they call me. initial impressions are the turbo is keener lower down the revs with slightly more pull through the rev range. There are no warning lights on the dash.The tickover and running are the same(no real difference) and no judder at shut off. It will stay in for me. of course this is on a 2.5tdi v6 and not the 130 pd engine
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    @ Swarcup
    Where did you get the blanking plate from or did you make it yourself? lastly was it easy to install?
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    a mate of mine gave it to me about 6 months back he had a spare laying idle, as for the instalation it took about 10 mins. had to be careful not to drop any of the bolts as retrieving may be a hassle but all together it was quite easy. Been through the annual mot today and the emission test or smoke test was passed with flying colours.The average K reading was 0.86, the fast pass limit is 1.5 and the ultimate allowed is 3 so all in all thats pretty ok to me although what 0.86 measures i dont know.
    Mar 2011
    Chester
    167
    There seems to be a few on e-bay that all look identicle (dimensions could obviously vary) so does anyone know a reliable supplier?
    EGR blanking plate 3mm Steel VW SEAT SKODA AUDI 2off | eBay UK
    Gonna have a look for a fitting guide.
    A4 (B6) 2.5TDI QUATTRO SPORT AVANT
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Cheers for the link to the blanking plates.
    Do i need 2 for my 2.5tdi?
    If you do find a fitting guide please post up the link as i would be very interested in having a read before i decide if i want to do the job or not.
    chrisash32's Avatar
    Manchester
    575
    Quote Originally Posted by bradster View Post
    Do you have a link to where you purchased the Allard kit from?
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    There is this one on ebay but says its for a 2.5 tdi VW transporter so guess it wont fit a 2.5 audi V6
    EGR Valve Delete Pipe VW T5 Van Transporter 2.5 Tdi NEW | eBay UK
    This is one for a 1.9 tdi
    Allard EGR Valve Delete Pipe Golf Audi Seat Skoda Tdi | eBay UK
    Jul 2010
    184
    Does anyone know if a golf EGR delete kit fits the A4?
    Is theer any difference in intake manis between transverse and longitudinal engines? Always see me more golf ones for sale thats all. lol.
