EM TuningMonster Motorsport
Results 1 to 10 of 10
    Jan 2005
    Cambridge
    171
    Problem with headlight
    All started in December. I had message on display saying: “Right Dipped Headlight”. Next day I went to garage. They “fixed” it and charged me almost 4 times more, than they told me they’ll charge. Anyway, headlight was working and I was happy, but… after 4 days it was raining and after this rain I got same message. I went to same garage again and said that they didn’t fixed problem (also I explained, that after each rain my headlight isn’t working). They checked and said that it was just coincidence. They changed burned bulb and everything was ok, but just till the next rain. Then again was same message. I went to garage and said that they should do something, because they are not fixing the problem. They told me that I need to leave my car and they will check was wrong, but I didn’t want to leave it, because after last time I left my car, they done something, that my front right turn signal didn’t work.
    So what should I do. I am driving without right headlight already more than week. I know it’s not good, but garage charged me and not fixed problem. Nevertheless they had done something with turning signal. I don’t want to go there again, but I paid money.
    I am confused. Maybe somebody knows why after each rain my headlight isn’t working? And what should I do with this garage? [img]/ubbthreads/images/graemlins/burningmad.gif[/img]
    phil1978's Avatar
    Dec 2004
    Home of the white stilleto
    183
    Re: Problem with headlight
    It could be that that the rain is some how getting into your electrics for your headlamp. Have a look at the back of the headlight to see if the covers are on properly, failing that check around the seals. It sounds like you're having bad luck with that dealer, why not try taking it to another one especially if it's still in warranty.
    Jan 2005
    Cambridge
    171
    I thought taking to another garage, but I paid money for nothing and they are not giving back. I don’t know how to deal with that.
    phil1978's Avatar
    Dec 2004
    183
    When was your car registered Laurra??
    And how many times have the bulbs blown??
    Jan 2005
    Cambridge
    171
    2001 August
    I don't know. I have this car from Nov 2004. Bulb is blown after each rain. Like I said, it started about 26th Dec
    I don't know how to check this covers myself, but I don't want to pay Ł50 again for "fixing" this problem.
    Jan 2005
    Cambridge
    171
    I know that they swindled. It is perfectly clear. And I hate that, but at that time I couldn’t do much. Iit is first car for me here, in UK . By the way, this garage is Nationwide autocentre. I thought they are good [img]/ubbthreads/images/graemlins/confused.gif[/img]
    And no, I don't know anybody with a car who can help me. That's why I am looking here for somebody from Cambridge [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    Nov 2004
    London UK
    2,614
    Ask Jedi he must know someone didnt i see on another post that he lives in Cambridge too! PM him and see if he can help out [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Jan 2005
    Cambridge
    171
    I just went to Audi and they said, that wires are melted AGAIN and they showed me why and how.
    The thing is, that cover is broken and there is no way to fixe it, need to change all headlight [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Does anyone know how much it costs?
    imported_Macduff
    You can probably find a used headlight at a breakers yard. A new one from Audi will cost a small fortune. If you don't want used part then try German, Swedish & French as they have new parts at discounted prices.
    If you don't buy the light from Audi you will have to find someone to fit it for you. Good luck.
    Dave
    Jan 2005
    Cambridge
    171
    OK, here are only few results I found. How to know which one is right one?
    94448 HEADLAMP-LH A4 11/94 > 85.00 Add
    94448 HEADLAMP-LH A4Q 11/94 > 85.00 Add
    94448A HEADLAMP-LH A4 11/94 > 45.00 Add
    94448A HEADLAMP-LH A4Q 11/94 > 45.00 Add
    94450 HEADLAMP-RH A4 11/94 > 85.00 Add
    94450 HEADLAMP-RH A4Q 11/94 > 85.00 Add
    94450A HEADLAMP-RH A4 11/94 > 45.00 Add
    94450A HEADLAMP-RH A4Q 11/94 > 45.00 Add
    94451 HEADLAMP-LH A4 00> 98.75 Add
    94452 HEADLAMP-RH A4 00> 98.75 Add
    94818 HEADLAMP LENS-LH VALEO A4 11/94 >
