Monster MotorsportBadger5
Page 2 of 2 FirstFirst 12
Results 41 to 53 of 53
Like Tree1Likes
Thread: Rear ARB replacement - suggestions
  1. #41
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    thansk Steve. sounds like a plan.
    swarcup - I saw your post #2. I meant that I haven't seen the drop links mentioned in other threads (not posts within this thread) although it's entirely possible that I have glanced over this. It makes absolute sense that they should be changed if they haven't been done recently. I'm off to see if I can find Meyle HD parts since I'm using them for the front control arms etc
    Anybody selling a polisher? PM me.
    A4 B6 3.0 Quattro Sport Avant
  3. #42
    Apr 2011
    I replaced my RARB at the weekend, what a difference... easy to do as well. I must admit I am thinking about changing the gearbox and diff oil as well..
  4. #43
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Done this today on mine. Took it to work (I'm the workshop manager for County Council), up on the ramp, 20 minutes, job done. The journey home incorporates three roundabouts. The last two are small, almost mini roundabouts. The first one I come to however, is a proper (lets see what happens) roundabout. I must have looked a strange sight as I went right around it :-)
    The car stayed noticably flatter than it would of previously. It instils more confidence in the handling (not that it was bad to start with), but most definately a worthwhile mod.
    Fitted my HIDS too, but not too sure. Bit too bright and no beam image pattern. I think these might come back off soon and I'll bite the bullet and do a proper Xenon upgrade.
    My XcarLink should be here tomorrow which will serve a purpose until funds are available for the RSN-e upgrade :-)
  5. #44
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    Quote Originally Posted by jbcalvin View Post
    Drop links - 8E0 505 465 AF - £25.95 each.
    Is 8E0 505 465 AC the same?
  6. #45
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    Pair of boxed OEM drop links (8E0 505 465 AC) at 12 quid each. the AC part supercedes the AF I think. Or vice versa.
    I'll try to fit them and the rarb today
  7. #46
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Nice link mate, let me know they definitely fit ...
  8. #47
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    625
    I changed the gearbox oil on mine at the same time as the RARB went on, did it on my MkIV for longevity. When it was done it seemed to go inot 1st & 3rd a lot easier... but that's very subjective.
    One word of advice... take the fill plug off BEFORE the drain plug. If you can't get the fill plug out after you've removed the drain plug, you're scuppered! (Seems obvious, I know)
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
  9. #48
    E4
    2004 A4 3.0 V6 Cabriolet
    Feb 2011
    London
    15
    My car is going in for the gearbox ecu on Tuesday
    Main dealer says I need a rear ARB. Garage wants confirmation from me that rs4 will fit straight on, If not...it's my problem not theirs?
    Advice please !
    3.0 v6 Cabriolet
    Silver / Blue Hood
  10. #49
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    Quote Originally Posted by fourcircle View Post
    I've used this seller before. They're good
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
  11. #50
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    Quote Originally Posted by E4 View Post
    Advice please !
    RS4 rarb fits straight in in place of the original matey.
  12. #51
    E4
    Feb 2011
    London
    15
    Just picked car up from Inde-tech at Bletchley . Fitted RS4 arb, drop links, bushes etc as per part numbers above...
    Wow. What a difference! Thanks to everyone here for convincing me to go for it !
    Really does corner very flat now. Seems to have eliminated under steer ?! Looking forward to dry weather and empty roundabout to try it "properly" :o)
    3.0 v6 Cabriolet
    Silver / Blue Hood
  13. #52
    A4 TC's Avatar
    1.8T quattro sline
    Nov 2006
    Toon Toon
    196
    Right list of part numbers and costs
    RARB - 8E0 511 409 AL - £58.80
    Bushes - 8E0 511 327 A - £2.78 each
    Brackets - 8E0 511 439 - £2.85 each
    Lostbok, can't understand how it was a 2 man job as I have a quattro as well, undid both the exhaust mounts at the rear of the car and it just needed pulling down very slightly to get the RARB in, did your guys take 1 wheel off to slide the bar in? I did mine lying on my back in the driveway, no assistance whatsoever....
    hello guys going to do this mod !
    So how many of each bushes , brackets and droplinks are needed to fit the rarb ?
  14. #53
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    Quote Originally Posted by A4 TC View Post
    1 Rarb, 2 of evrything else
    How to fit your RS4 rear anti roll bar (rarb)
