fourcircle
nj
So I finally got round to fitting my cruise control and DIS stalks today. I was a bit apprehensive about the vagcomming but it seemed to go OK. CC works well but when I press the reset button on the DIS stalk the centre display just goes blank. If I press it again it reappears. the end up-down buttons do nothing. I didn't ground a pin because I couldn't see details of what exactly to ground (does anyone have a link to a thread that shows this clearly?)
I also have an airbag warning on the display so I'm trying to figure out wtf i've done to cause that.
the only thing I can think of is when I recoded the steering wheel module (scsm) the original value corresponded to a basic steering wheel, rather than 3 spoke, so when I entered the new code I chose the corresponding one for 3 spoke steering wheel. I'll need to redo that tomorrow. Does anyone know if i'll then have to redo the other parts of the vagcom prodedure?
my scsm turned out to be 8E0 953 549 Q by the way so should be good for cc, DIS and heated steering wheel.
Life would be too simple if these things worked out perfectly first time
cheers
nj
cheers
nj
