Monster MotorsportVolks Autos
Results 1 to 12 of 12
Thread: engine mount
    Sep 2010
    engine mount
    hi guys just a quick question please, i had a scan done on my car, and is showed up a fault with the engine mount, now as far as i am aware there are 2 engine mounts 1 with the sensor and 1 without, do i have to get both of them chaged? as i cant feel anything wrong with the engine mounts? but soon i will get the engine mount changed the 1 with the sensor, do you think i should change both or just the one with the fault? and also how easy or hard is this job? and any idea what the costs might be?
    thank guys
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    id change them both
    but if its not causeing a problem just leave it as is
    Jul 2010
    184
    The passenger side one has the solenoid. Its about 70-80 quid.
    Do you have any issues or is it just a code being thrown?
    Sep 2010
    no problem at all mate, drives exactly the way it should, so i dont know why i was told after geting the scan i should change it asap, after its changed does it make the car any smoother? or quiter?
    Dec 2008
    48
    My car throws up this fault to, are they easy to change , i`d have a go if there only 70-80 quid...Don`t they control how the engine rocks....
    simon.m's Avatar
    Oct 2009
    2,746
    it may just be a snaped wier you guys have i had this code and thats all it was re did it all is fine no code at all it works some thing like this on tick over there is a pin kinda thing that pushes into the engine mount and heats it up so as to make it softer to take some of the vibrashon out then when you drive off it pulls the pin out the mount gose cold and hardens back up
    Dec 2008
    48
    i`ll check for the broken wire cheers...easy done as my undertrays still missing after being ripped off in the snow a few months ago!!!!
    simon.m's Avatar
    Oct 2009
    2,746
    mine was wier and the black block part just super glued it on ;-) works ok now
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    the drivers side normally goes on the 2.5TDI and they are a bit of a pain to do, a balancing act with jacks and front bumper off if i remember reading about it rightly.
    Sep 2010
    thanks for the replies guys, so i take i should change both mounts, and would i expect the car to be more smoother? and also any idea if it a expensive job? cheers
    Turkster's Avatar
    Dec 2007
    2,723
    depends on where you are mate and what engine you have, all i know is the 2.5TDI will cost you about £100 each new from main dealer, there is a member here who lives in north London who can give you a good price, Iv not used him yet but he does have a good rep with the other lads and he is on my list of jobs to be done to my car soon, so send him a PM mate,
    adamss24
    Sep 2010
    my car is an audi a4 52 reg 1.9 tdi 130 bhp but it has been remaped to i think 170bhp and am from Leeds
