JMB RetrofitsSky Insurance
Results 1 to 9 of 9
Like Tree4Likes
  • 2 Post By quattrojames
Thread: B6 Part Numbers Thread
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    The aim of this thread is to answer the often asked "What part number is this?" question.
    It is reliant on the accuracy and contributions from members, so please if you have a part number you know is right then PM me with it and I will add it into this thread. It is only as good as the information you send me.
    B6 Accessory Catalogue: http://www.vaglinks.com/Docs/Catalog...ccessories.pdf
    I will aim to keep it as clear and concise as possible, initially with sections for:
    • "S-Line style" parts.
    • S4 Parts.
    • Interior parts
    • Exterior parts
    • Engine and suspension.
    Obviously as time goes by I reserve the right to alter/amend this! Please bear in mind this information is supplied with good intention, but always double checked before ordering.
    I will keep the thread closed between additions so it doesn't get untidy and diluted with chat.
    For a break down of part numbers see here:
    VW and Audi part numbers system explained in ETKA
    And don't forget:
    8E9 = AVANT
    8E5 = SALOON
    deanski and Widemonkeys like this.
    Mar 2008
    Dorset
    13,856
    Interior Parts
    GLOVE BOX DAMPER/LIGHT SWITCH:
    • 8E2 880 324
    Compatible SCCM modules for doing the Cruise and DIS Upgrade
    • 8E0 953 549 Q
    • 8E0 953 549 N
    Retro fitting a washer level sensor, which you need to do if retrofitting DIS...
    • Sensor - 7M0 919 376 - £6.57
    • Washer - 7M0 919 382 - £2.16
    • Wiring loom connector for sensor - 7M0 973 202 - £4.87
    • 3 x wires for connector - 000 979 133 AB - £2.45 each
    Central Electrics Module that supports Auto Headlights:
    • 8E0 907 279 F.
    Front seat repair kit (for if rear panel starts to pop off):
    • 8E0 898 035
    Puddle Lights (and footwell lights?):
    • 8D0 947 415
    Driver's side Window switch finger plate ( front electric windows only)
    • 8E2 867 172 A 7PE
    RS4 Handbrake cover:
    • 8E0 711 327 M (8UD)
    Brake Light Switch:
    • U1K2 945 511 RD W A-A061
    8E0 863 284 B 6PS centre console compartment and cigarette lighter soul black - £45.35
    8E0 863 321 D 7PE trim for switch soul black - £17.22
    8E0 863 276 B 6PS trim for handbrake lever soul black - £1.42
    8E0 857 967 6PS cover for ashtray soul black - £15.07
    8E0 857 961M 6PS rear ashtray soul black - £15.73
    8E0 853 985 B7DL door sill plastic cover strip left - £8.86
    8E0 853 986 B7DL door sill plastic cover strip right - £8.86
    8E0 864 261 AN 6PS manual gearstick surround soul black - £36.87
    8E0 711 463 C 6PS hand brake lever trim soul black - £11.18
    8E1 919 094 5PR headlight range/height adjustment knob - £21.12
    Stumbled across the part number for the
    4B9867899 4PK Warning triangle latch. Audi A4, A6 AVANT Rear lid trim panel clip for warning triangle - 4B9867899 4PK - Stoke Audi Parts
    Mar 2008
    Dorset
    13,856
    Engine Parts
    Coilpack recall for the 1.8T (163bhp-190bhp) 2000-2005 are all being replaced with:
    • 06A 905 115D Which Has a new style top/cap (looks good)..
    • 8E0 199 379bj 2.5 TDi quattro engine mount (same both sides).
    Mar 2008
    Dorset
    13,856
    Exterior Parts
    PAS Screen Wash Bottle And Brake Fluid Cover Smooth:
    • 8E0103927F
    AirCon Pipe Cover(wrinkle effect):
    • 8H0103928
    Small Battery Cover:
    • 8E2819422a 01C
    AERO WIPERS:
    • 8E2955408C - OS WIPER ARM
    • 8E2955407C - NS WIPER ARM
    • 4B2955425C - AERO BLADES
    Non Aero Wiper Blade Clip
    8E0955247 82p + vat
    Water Deflector (at base of screen surrounding wipers):
    • 8E2819403AO1C
    Heated Fan Washer Jets:
    • 5MO 955 986 9B9
    SEAT Cupra splitter:
    • 1ML 805 903
    Avus Silver Wheel Colour:
    • VLLS 0M6 Z17 (2 x 150ml cans one top coat & one lacquer)
    Quattro Grille Badge:
    • 8LE0853736 2ZZ Badge
    • 8L0807180 Clips (x2)
    EGR Cleaning (1.9TDi 130):
    • Rubber 'O' Ring seal - SN90927302 - £4.04 at TPS.
    • EGR Gasket - 069131547D - £2.41 at TPS.
    Rear Number Plate Light Surround:
    • V8E08275763FZ
    Rear Tailgate Release Solenoid:
    • 8E5 962 115 (appears same for saloon/avant)
    Mar 2008
    Dorset
    13,856
    S4 Parts
    S4 Door Blades:
    • 8E0 853 959 A 7DL [n/s Front]
    • 8E0 853 960 A 7DL [o/s Front]
    • 8E0 853 970 A 7DL [n/s Rear]
    • 8E0 853 969 A 7DL [o/s Rear]
    S4 door sill covers:
    • 8E0 853 373 A01C - £99.01
    • 8E0 853 374 A01C - £99.01
    • 8E0 853 375 A01C - £41.77
    • 8E0 853 376 A01C - £41.77
    Carbon interior trims:
    • 8E0 867 420 L 7V7 - £151.21
    • 8E0 867 410 L 7V7 - £151.21
    • 8E0 867 409 L 7V7 - £151.21
    • 8E0 867 419 L 7V7 - £151.21
    • 8E2 853 189 AQ7V7 - £186.73
    • 8E2 853 190 AG7V7 - £186.73
    Mar 2008
    Dorset
    13,856
    "S-Line Style" Parts
    S-LINE FRONT:
    • S-Line Front Bumper Spoiler #8E0-807-110-B-GRU
    • S-Line Grill (lower) #8E0-807-647-D-01C
    • S-Line RH Fog Light Trim #8E0-807-682-C-01C
    • S-Line LH Fog Light Trim #8E0-807-681-C-01C
    S-LINE REAR LOWER VALANCE TWIN EXHAUST CUTOUTS AVANT:
    • 8E9 807 521 G GRU
    • STICKER FOR ABOVE 8E9 807 800A
    S-LINE DOOR BLADES:
    • 8E0 853 959 C 7DL [n/s Front]
    • 8E0 853 960 C 7DL [o/s Front]
    • 8E0 853 969 C 7DL [o/s Rear]
    • 8E0 853 970 C 7DL [n/s Rear]
    AllyMc and rifc38 like this.
    Mar 2008
    Dorset
    13,856
    Service Parts
    NB Some of these apply to the B7 range also.
    Oil Filters:
    1.6 also 2.0 & 2.0 FSi 06A 115 561B
    1.8T(AVJ) 068 115 561 F
    2.4 V6 078 115 561 J
    1.9TDi & 2.0TDi 074 115 562
    2.5TDi 059 115 562
    3.0TDi > 8E8144749 057 115 561 L
    3.0TDi < 8E8144750 057 115 561 M
    Air Filters:
    All models 06C 133 843
    Fuel Filters:
    1.6/2.0/2.4 1J0 201 511 A
    1.9TDI 1J0 127 401 A
    2.0TDI (Excl BPW) 8E0 127 435 A
    2.5TDI 057 127 435 D
    3.0TDI 8E0 127 401 C
    Pollen Filters:
    All models standerd filter 8E0 819 439
    All models pollution filter 4B0 819 439 C
    All models pollution filfter 05 onwards 8E0 819 439 C
    Spark Plugs:
    1.6 101 000 033 AA
    2.0 101 000 033 AG
    2.0FSi 03 < 101 905 620
    1.8T 101 000 063 AA
    2.4 V6 101 000 035 HJ
    Glow Plugs:
    1.9TDi >02 >>8E2148697 N101 401 05
    1.9TDi 02> 8E2148698 N105 792 01
    2.0TDi N105 798 02
    2.5TDi 059 963 319 H
    Wiper Blade Kits:
    All models 04> 4B2 998 002
    Wiper Blades:
    All models LH >04 8E0 955 425 A
    All models RH >04 8E2 955 425 A
    Cam Belt Kits:
    1.6 06A 198 119
    2.0 & 1.8T 06B 198 119 A
    2.0 FSi 03>04 06F 198 119
    2.0 FSi 05> 06F 198 119 A
    2.4 V6 078 198 119
    1.9 TDi >02 >8E2297100 038 198 119
    1.9 TDi 02> 8E2297101> 038 198 119A
    2.0TDi (Excl BPW) 03G 198 119
    2.5TDi 059 198 119B
    FRONT Brake Pads:
    1.6 288x22mm 8E0 698 151 M
    2.0/2.0FSi/1.8T/2.4/1.9TDi/2.5TDi >05 288/312x25mm 4B0 698 151 J
    2.0/2.0FSi/1.8T/2.4/1.9TDi/2.5TDi 05> 288/312x25mm 8E0 698 151 K
    3.0TDI 8E0 698 151 G
    REAR Brake Pads:
    1.6/2.0/2.0FSi/1.8T/1.9TDi/2.5TDi/ >04 PR-1KD - >> 8E4180000* 8E0 698 451 K
    1.6/2.0/2.0FSi/1.8T/2.4/1.9TDi/2.5TDI 04> PR-1KD - 8E4180001>> 8E0 698 451 L
    3.0TDi 8E0 698 451 J
    FRONT Brake Discs:
    1.6 PR-1LZ- 288x22mm 8E0 615 301 P
    2.0/2.0FSi/1.8T/1.9TDi PR-1LB/1LE-288x25mm 8E0 615 301 Q
    2.4/2.5TDi PR-1LT/1LF- 312x25mm 8E0 615 301 R
    3.0TDi PR-1LA - 320x30mm 8E0 615 301 AD
    REAR Brake Discs:
    1.6/2.0/2.0FSi/1.8T/1.9TDi PR-1KD- 245x10mm 8E0 615 601 P
    2.4 V6 8E0 615 601 Q
    FRONT Brake Hoses:
    All models 8E0 611 707 G
    Clutch Kits:
    2.0 131 bhp 05> 06B 198 141 CX
    2.0T 05> Excl quattro 06C 198 141 CX
    2.4 01>03 078 198 141 EX
    1.9TDi 115 bhp 038 198 141 FX
    1.9TDi 130 bhp >03 06C 198 141 AX
    1.9TDi 130 bhp 04>05 06C 198 141 DX
    1.9TDi 131 bhp 038 198 141 FX
    2.0TDi 05> 038 198 141 GX
    2.5TDi 06C 198 141 BX
    Water Pumps:
    1.6/2.0 06B 121 011 LX
    2.0 FSi 06B 121 011 MX
    1.8T 06A 121 012 X
    2.4 V6 078 121 006 X
    1.9 TDi 038 121 011 JX
    2.0 TDi 038 121 011 KX
    2.5 TDi 059 121 004 EX
    Radiators:
    1.6/2.0/1.8T/1.9TDi MANUAL- 632 X 414 X 27 MM 8E0 121 251 A
    1.6/2.0/1.8T/1.9TDi AUTO 8E0 121 251 AQ
    Ignition Coils:
    1.8T 06A 905 115 D
    AIR MASS METERS:
    1.8T AVJ 06A 906 461 LX
    1.9TDi 100 bhp 02> AVB >>8E2120000 038 906 461 C
    1.9TDi 100 bhp >02 AVB 8E2120001>> 038 906 461 BX
    1.9TDi 130 bhp >01 AWX/ AVF >>8E1080000 071 906 461 AX
    1.9TDi 130 bhp 02> AWX/AVF/BKE 8E200000>> 074 906 461 BX
    2.5 tdi sport quattro saloon: 059 906 461G
    Mar 2008
    Dorset
    13,856
    Suspension Parts
    Suspension Parts.
    RS4 rear Anti-Roll Bar.
    RARB - 8E0 511 409 AL - £58.80
    Bushes - 8E0 511 327 A - £2.78 each
    Brackets - 8E0 511 439 - £2.85 each
    Drop links - 8E0 505 465 AF - £25.95 each
    Tie Rod Ends:
    All models LH/RH excl sports running gear -PR-1BV 4F0 419 811 E
    Wishbone Link Arms:
    All Models 01>07 8E0 407 151
    Mar 2008
    Dorset
    13,856
    Votex Bodykit
    Front Chin Spoiler: 8E0 071 609 9AX
    Left replacement Grill: 8E0 071 612 L041
    Right replacement Grill: 8E0 071 612 R041
    Middle replacement Grill: 8E0 071 612 M041
    Replacement clips (bag of 10 clips and 10 screws): 000 071 612V
    Side Sill Kit: 8E0 071 685 9AX
    Rear Skirt: 8E0 071 610U 9AX
    Middle replacement Grille: 8E0 071 610 9AX
    Adhesive: 000 071 780
    Outer Grilles (single exhaust?): 8E0 071 611B 041
    Outer Grilles (dual exhaust?): 8E0 071 611A 041
    Rear Trunk Spoiler: 8E0 071 645 9AX
    EDIT some more useful part numbers here:
    http://www.audi-sport.net/vb/a4-a4-c...ml#post1748477
