vorsprung dork
fixed my glovebox hinge today thanks to quattro james thread! took about 45 mins! only thing i did differant was getting the pins out! as hard as i tried i couldnt get the pins out according to the instructions in the thread! so i turned the glovebox on its side and used a centre punch to drive out the righthand pin! this is easy and accesable the left hand pin is not so i drilled a small hole in the trim to fit the punch in! the hole is about 3 mm and can be seen with the door open! but to be honist if you were to notice it you neeb to be a trainspotter! if you try this fix yourself you will see what im on about when you remove the glovebox!!!!!!!! thank you james saved me £££££££££££
