JMB RetrofitsEM Tuning
    Apr 2011
    11
    cabriolet Bose problem
    I've just bought a 2003 Cab which has Bose written on the front speakers and a Symphony II head unit.
    However, I got no sound whatsoever from the radio, cd or tape.
    I've tried a different Symphony headunit and that is the same.
    ANy ideas where I should be looking?
    Jun 2003
    World of my own
    9,813
    The Bose system is fully amped so I would start by checking the Bose amp (it'll be in the boot behind the trim usually on the drivers side). Ensure the amp is getting both a 12v permanent feed and the switched 12v feed from the HU (when HU is on). Not sure on the cabrio if the amp is separately fused, but worth checking the fusebox first to see if any fuses are blown.
    Alex Turner
    Apr 2011
    11
    Thanks mate.
    Do you know how to remove the relevant trim to get at the amp?
    Jun 2003
    World of my own
    9,813
    Not specifically on the cabrio. It's usually just a case of removing the plastic push studs and peeling it back
    Alex Turner
    Apr 2011
    11
    hmm doesn't appear to be a specific fuse for the amp that I can see (which seems odd).
    Looks like the amp has one inline or is faulty. Now I just need to figure out how to get the trim off...
