AH FabricationsSky Insurance
Results 1 to 13 of 13
    Feb 2011
    55
    Smelly Air-con - regas or just 'clean'?
    Have recently had really bad smells coming from the Aircon of my 7 year old S4 - especially after start-up for a couple of minutes - what is the best remedy? Any advice?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    The BEST remedy is to visit Audi (or a similar ac specialist) and have a deodorising 'bomb' put in the air intake to sterilise and deodorise the system.
    Another (cheaper) option is to buy some Wynn's Airco or similar and do it yourself. I did mine last year and it's still fine now.
    ADC74's Avatar
    Master Baker
    Jan 2011
    Staffordshire
    148
    I too have the same problem, how do you apply that 'Wynn's Airco' ?
    ATR vs V6 TDI
    deanski's Avatar
    wax on, wax off
    May 2010
    Lancashire
    374
    usual method is to slide you passenger seat right forward and tilt it forward as far as it will go. you then pu your aircon on full on the recirculate setting then place the can on a towel behind the passenger seat and depress the button til it clicks. this jams the spray on and the aircon sucks it through the system. some you spray directly into the dash vents so double check the label of the one you buy.
    A4 B6 1.9 tdi 130. Slowly modding but don't tell the missus.
    Front ambient lighting
    Eibach sportlines.
    Audi TT Alloys.
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    I had a really persistent smell with mine and the advice I had was to try hot and then cold, then bomb it.... and also to run it on "ECON" without the aircon for some of the cycle as I was getting a surge of the "wet tramp" smell when I switched the aircon on and off.
    I eventually got rid of it for 12 months + by running the car with heating on "HI" for 30mins+, then "LO" for around 15-20mins (i.e. until it's properly cold), THEN put the Wynns in there.... and once the spray is finished, pop the econ button in for the tail end of it all.
    LostBok/BahnStormer77
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by ADC74 View Post
    I've always found straight into the system to be the most effective. Take the pollen filter out on the nearside and with the fan on full (I can't remember the recommended temperature I'd need to check that) spray it into the air intake.
    The can says there's enough for two treatments, but I dumped it all in in several long bursts over about ten minutes.
    ADC74's Avatar
    Master Baker
    Jan 2011
    Staffordshire
    148
    Popped to Halfrauds this morning & bought the 'comma' version of this product, £10 / 10 mins easy fix - happy days !
    ATR vs V6 TDI
    Point_Audi's Avatar
    Vorsprung durch Technik
    May 2010
    Ireland
    575
    Mine was the same not so long ago, I used some Wynns by spraying it into the pollen filter holder but I didn't notice much difference. So I inquired how much Audi would charge to have it cleaned. £30 for the clean, wash/hoover, coffee and courtesy lift to work! Bargain, and the Air-Con smells so much better!
    A4 B8 2.0TDI S-Line Executive
    Events Moderator
    Ireland/Northern Ireland
    Widemonkeys's Avatar
    Aug 2010
    Durham, Durham, United Kingdom
    274
    I saw on another forum that someone used dettol anti bacterial airfreshener.they sprayed it in to the pollen filter holder while heater on full blast and that worked for them.
    02 A4 B6 1.9tdi Avant sport 130bhp, 18" RS4's, Cruise control, Armrest, Ambiant lights, LED number plate bulbs,Pressed number plates, rear RS4 ARB, blacked out grills.
    Wanted : S line front and rear bumpers , S4 lower grill, s4 door blades
    Feb 2011
    Whipsnade UK
    94
    3.0V6 Quattro Convertible Tip - Crystal blue, blue roof, grey leather
    Upgrades: RS6 18" Wheels, Pirelli Zero Rosso 235/40R18, Philips extreme bulbs, brodit phone holder, Wind Deflector, BMC Air Filter
    Jan 2009
    125
    Half can of fabreeze into the intake under the pollen filter and the other half in the car on recirculate worked a treat on mine. No smells since, well, other than fabreeze summer mist or whatever!
    Black 2.5tdi 180 Quattro Sport (210bhp tuning box) , Votex Kit, 19" Rs4 replicas, HID's, Led Sidelights, Exhaust & Some Black bits.
    To do : LCR Splitter
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    I've always used the Comma treatment; works perfectly every time.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    May 2010
    106
    Aircon bombs can be had from poundland, since it so cheap i do mine twice a year.. smells lemon fresh, never bother with the old magic tree now
    Audi A4 B6 Avant 04 (1.8T 190 Quattro)
    Mods - CustomCode Stage 1, Cruise Retrofit, HID's, B7 Key.
    Wanted : Auto light switch, auto dimming mirror
