Monster MotorsportBadger5
Results 1 to 9 of 9
Thread: speedo
    simon.m's Avatar
    Oct 2009
    2,746
    speedo
    so as i was driving home today thought id strech her legs as i dont go over 70 really any how got to 80 and as it started to clime the speedo started to flick say from 80 to 90 and back again really strange but it did this just above 80 now im not to worred as i always sit at 65 to 70 but would like to no i did a scane and all it come back with is fault 01312 powertrain data bus 79-10 please check fault codes intermittent.
    any help would be good
    thanks
    simon
    simon.m's Avatar
    Oct 2009
    2,746
    any boddy??????????
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Speed kills Simon. Stick to the limit
    Have you seen this? Not that it's much help.
    01312 - Ross-Tech Wiki
    simon.m's Avatar
    Oct 2009
    2,746
    i no mate and i mostly do under 70 but thought id clear the pips as i do mostly town driving and also still have the problem with the g75 valve or what ever it is when ever i get to 3k in 3rd 4th it kicks into safe mode evan though its a new one any how was wondering if the car has a speed sensor or some thing that i can clean maybe
    simon.m's Avatar
    Oct 2009
    2,746
    so could it be this then ? if so where is the part located so i can clean them
    01312 - Powertrain Data Bus
    01312 - Powertrain Data Bus: Faulty
    Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    Possible Causes
    • Databus Wiring and/or Connector(s) faulty
    Possible Solutions
    • Check Databus Wiring and/or Connector(s)
    Mar 2008
    Dorset
    13,856
    I don't know mate sorry, more googling required!
    simon.m's Avatar
    Oct 2009
    2,746
    thanks james think ill look into seeing if i can clean the sensor if it has one its like the old cable snaging thing but sure these cars dont have a speedo cable
    May 2011
    SAME THING!
    Hi i have a '97 A4T which does exactly the same thing.... So far i have changed the clocks and the speed transducer on gearbox, but still the same, wavers around 80-90, then drops and stays at 80. I read another thread on a site i didn't save sadly, a guy on there had the same problem on a skoda.... Strange this problem is happening on such varied cars in the VAG! Have you got any further forward yet? He says hopefuly.....
    simon.m's Avatar
    Oct 2009
    2,746
    no mate iv not evan looked yet was going to start with cleaning the wier conectors first will if and when i get my car back after some num nuts puled out on me
