Results 1 to 11 of 11
Thread: cruise control
    Apr 2011
    160
    cruise control
    i know this has been covered many times, but.....
    i want to fit my cruise control. and i know you need vag-com, which i have never used but my question is can i set up the cruise with the free ware versions or do i need the full version.
    Fossie
    Rhubarb Triangle
    3,969
    Have you got the lead ?
    Apr 2011
    197
    you need full vcds and advise you use genuine ross tech cable not a clone
    Sep 2006
    222
    same as above as ive just done it to mine
    Apr 2011
    160
    Ok, no but im looking to get a cable and software and that will be one the first jobs i'll do with it. just wasn't sure if i needed to buy the software or if i could do it with the free-ware thats about.
    Fossie
    Rhubarb Triangle
    3,969
    Why not find someone near to you who will help you out ?
    VCDS user map on here will show you who is close to your location and prepared to help.
    Apr 2011
    160
    cool will do that may be easiest way dont want to do something i shouldn't, im more mechanically minded than electrically minded.
    Jan 2011
    Gainsborough
    68
    Where are you located Jama665?
    Apr 2011
    160
    In somerset, south of bristol
    Fossie
    Rhubarb Triangle
    3,969
    Have you checked the VCDS users map ?
    http://www.audi-sport.net/vb/vcds-fo...%2A%2A%2A.html
    Jan 2011
    Gainsborough
    68
    Too far for me I'm afraid but check the map for someone local
