AH FabricationsVolks Autos
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Pabs
Thread: radiator fan
    deanski's Avatar
    wax on, wax off
    May 2010
    Lancashire
    374
    radiator fan
    should these be running all the time? noticed today that mine runs regardless of air con being on or engine temp. sorry if its a daft question just never noticed before.
    A4 B6 1.9 tdi 130. Slowly modding but don't tell the missus.
    Front ambient lighting
    Eibach sportlines.
    Audi TT Alloys.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,704
    No it shouldn't be. Have you tried searching? I think this has been discussed before.
    Feb 2006
    Lincolnshire
    691
    I've read some threads where the thermostat was the culprit, I'm guessing your car thinks the coolant is hotter than it is? It might be worth checking/replacing the coolant temp sensors on the lower radiator outlet and back of the engine before the thermostat though.
    I'm not sure if there is an electronic fan control unit on the B6, maybe somebody could chip in with an answer to that.
    If you could hook it up to VCDS/VAG-COM then hopefully there will be some error codes to pin point things.
    Audi S3 - 2002MY - Denim Blue
    Sep 2010
    167
    Can you tell us which fans are running, both the right and left hand side ones? the right fan is a viscous fan so it will look like its turning all the time, more when hot, but if your left one is on without the air con on and the engine very hot then there may be a fault, possible ect fault, have you had the diagnostic machine on it?
    deanski's Avatar
    wax on, wax off
    May 2010
    Lancashire
    374
    the car runs no faults on vag com. if you are looking at the car from the front, it is the right one that is turning with the belt flying around. I have replaced the coolant sensor at the back of the engine.
    Eibach sportlines.
    Audi TT Alloys.
    simon.m's Avatar
    Oct 2009
    2,746
    Think that's the viscus fan mate u will no if it is or not as u can stop it by hand as its not spinning fast enough untill the car gets to hot
    Mar 2008
    Dorset
    13,704
    Quote Originally Posted by simon.m View Post
    Be BL***Y careful if you're trying this at home!
    Pabs's Avatar
    Jun 2010
    Manchester
    611
    Check the relay thinks its number 219 that controls the fans, its located under the ecu bit of a pain to get to as you have to take the wipers and scuttle panel off. Mine had signs of corrosion from water damage, changed the relay and the coolant temp sensor at the rear of the cylinder head and everything works perfect. The fan control unit is located on top of the fans, hopefully it wont be that as its 141 + vat from Audi for a new one, thats what i thought was wrong with mine at first..
    mcnicodt likes this.
    A4 1.8T 190 S-Line, Stage 2 Shark Performance Map 230 BHP, Pipercross Panel Filter, Forge 007 DV, Blue Flame Performance Exhaust + High Flow Sports Cat, 8k HID Lights, 8k HID Fog Lights, LED Sidelights, LED Number Plate, Front + Rear Ambient Lighting, LED Interior Bulbs, Grooved Dimpled Disks, Ultimax Pads, RNS-E DVD, Tinted Windows, S4 Grill, Votex Rear Skirt, BOSE, Leather, Engine Covers, S4 Mirrors, RS4 Pedals, Gloss Black Wrapped Grills, 19" BBS LM's Summer, 19" RS6's Winter, Coilovers
    Jan 2011
    661
    I had mine parked the other day, ignition on but hadnt been driven anywhere and my engine fan ran for a while, I just assumed it was a sensor somewhere telling it to cool things down.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    deanski's Avatar
    wax on, wax off
    May 2010
    Lancashire
    374
    thanks guys. it doesnt run with the ignition on. just when the engine is running.
    Eibach sportlines.
    Audi TT Alloys.
    simon.m's Avatar
    Oct 2009
    2,746
    sounds like the viscous fan to me
