Sky InsuranceJMB Retrofits
    HipAl's Avatar
    Mar 2011
    Baildon, United Kingdom
    11
    Spacer Help Please...
    Hi, looking into getting some rear spacers for my A4 avant, cant decide what size. I have on 19x8.5 et 48
    Would a 10mm spacer be too big? Any advice would be great.
    Thanks in advance Alex..
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    10mm spacer with et38 so you are still within the safe limit's. Just make sure they are hub centric.
    AUDI A4 190T S-LINE.
    HipAl's Avatar
    Mar 2011
    11
    Thanks CMD WOULD 10MM be noticeable or would you go bigger.
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Well if you think a 15mm spacer added to your et48 will give you et33 which is doable with a with a 225 tyre. Is your car also lowered as it could rub maybe. I have 15mm on the rear and 10mm up front without any problems.
