Quick question to anybody with the part catalog thing!
Im in the process of fixing my avant rear wiper and the L shaped bit of washer jet pipe that clips onto the motor seems to have gone slack and no longer creates a seal.. infact, it squirts water across the inside of the car when theres no boot trim on!
Can this L shaped connector be bought separate? If so what was its part number, i imagine if i goto audi without it they will try sell me an entire bootlid or similar
Btw if anybody is experiencing a very slow wiper arm, or stuck couped with a hot motor it means the gearbox is jammed. I can imagine its quite common since the water pipe travels through it and and a leak will end up in the gearbox. If you remove the stuck arm, oil it up and work it back and forth in a vice for about 30mins it eventually frees up and is now working fine!!
