Only when cold & after a couple of mins driving - no throttle response after coming to a stop/slowing to a stop. Leaves me stranded at junctions!
Shut engine off - restart - won't rev, even in neutral. Sits on 1k revs.
[FONT="]Place in neutral and it wont rev whatsoever, place in Drive or Reverse and put foot down, after several attempts itll kick in, and then drive as normal for the rest of the day! - Always OK when warm.
[/FONT] Indications
None! No transmission flashing lights, no CEL or DTC's, nowt in memory when scanned with VCDS
Tried
Throttle Body & Butterfly plate removed & cleared of gunk then re-aligned adaptation via VCDS
Garage checked for vacuum, lean codes and emissions ok
MAF & Air Filter replaced
Brake Pedal sensor replaced it cuts out throttle and is known fault
10 tanks of Premium fuel used, and countless injector cleaners/additives over past months.
This has been occurring for about once a week for 6 months now.
Any advise gratefully received!!
A4 cab 3.0 V6 Auto - ASN 8H7 2003
[/FONT] Indications
Tried
