oh right i think the only other place you would find an ajuster then is on the hand brake its self inside the car but im not 100% sure i no when i did my back brakes i had to use the winding in tool to push the pistons right back in as it would not ajust till i did this and then i had to pull the hand brake up a few times
Had a quick peak at elsa, the rears are self adjusting, but says they would only need readjusting if you had changed discs etc, of which you have done, ideally you need the elsa article to know how to do properly.
