Monster MotorsportChris Nott
    Mar 2011
    ELECTRIC SEAT FAULT
    hi i have a 2003 a4 cab the divers seat works fine on the switch on the lower part of the seat but the easy entry switch only operates in one direction. if you take the seat forward with the lower switch it will return with the easy entry switch. Is there a way of resetting or re programming? hope someone can help.
    Apr 2011
    Have the same problem, did you find a solution to this?
    Thanks,
    Walter.
