AH FabricationsBadger5
Results 1 to 11 of 11
    Mar 2011
    6
    Gearbox ECU’s by ECU Testing.com
    Hi Guys,
    I've got a A4 2.0 Multitronic with the very common problem of the "PNRDS" lights flashing and the engine just revs. After much reading and research on the net the answer seems to be the same - The ECU is shot. I've found a company in Nottingham, ECU Testing.com. Has anybody used them before? Can anybody recommend them? I'm from South Africa and need to ship the ECU to the UK. It seems a bit like blind faith to just send the thing 13000km and hope for the best. As the agents in SA charges about an arm and a leg, I figured it much cheaper to send the part to the UK, repair the thing, ship it back. I'll still be able to get away with about a quarter of the price. Could you please let me know? or
    will89's Avatar
    Jul 2010
    362
    I had mine changed but not at this place, they replaced it with a new one from Audi in Germany. Apparently they are set to the car in Germany. It did need programming and setting up too so not sure if yours will need to be done? If it does then youll be stuck with the car on your drive and will have to get it lifted on a flatbed and too a specialist in SA. I would check to make sure it won't need reprogramming before removing it and sending it. I had the exact same problem as you too.
    Mar 2011
    6
    Thanks Will89,
    A quote from their websit
    " We can now rebuild your Multitronic gearbox ECU with no need for any programming work to be done afterwards. Just plug in and go!"
    I just hope it's true.
    will89's Avatar
    Jul 2010
    362
    Sounds ok then might be worth a try
    Mar 2011
    6
    Hi Will89,
    The ECU is packed and ready to go. FedEx is picking it up tomorrow morning. It should be about two week before I have it back. Will post the result and costs then. Thanks for your input.
    will89's Avatar
    Jul 2010
    362
    Ok let us know how you get on
    a4 2.4 se's Avatar
    V6
    Aug 2006
    Leicester
    110
    Hi i had my Multitronic ECU done at ecu testing.com very good service i had it back in 3 days
    Mar 2011
    6
    It's been two weeks now and the Audi is going again. CPU repaired and no need for coding, just plug and drive. Yippee. So far so good. The shipping to the UK took 3 days, repair of the ECU 2 days and the shipping back to SA 7 days (hey what can I say,its Africa). The cost in total was 350 pounds vs. 2300 pounds. I can recommend them. Great service. Great turn around time. Great saving. Thank you to everyone that replied to this thread!!
    will89's Avatar
    Jul 2010
    362
    Great news! Will be keeping them in mind now just in case anything happens to mine!
    jan
    Jan 2012
    Hi
    Just read that you had an ECU problem, i have the same would you be so kind to give me details of company in Nottingham and how you went about
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    the clue is in the first thread ??? ECU Testing.com google also works very well these days lol
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
