Thread: Temperature
    WHITEY_1's Avatar
    Bugz Champion, Starship Legend Champion
    Jan 2006
    S-Wales
    229
    Temperature
    O.k Lads and girls,
    Ive got a bit of a problem with my water temperature if I drive the car from cold and do about 5 miles the temperature gage goes to just under 90 oC when I pull over and check the water pipes the top pipes going to the head are hot and the water pipes going to the bottom of the engine are cold! Could this be the water pump or the thermostat?
    Any help much appreciated
    AU01 A4's Avatar
    Jan 2009
    Huddersfield
    211
    If you dive it hard dose the temp go past 90, and then back off dose it come down?
    Audi A4 1.8T quattro S Line Avant
    WHITEY_1's Avatar
    Jan 2006
    S-Wales
    229
    Now its just going past 90 and it will drop back down but then it will go back up to 90 if I drive 4 or 5 miles!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    What you describe (bottom pipes cold) is quite normal for a newly started engine tbh.
    Once the engine warms up, does the guage stay at 90c? If it drops down when you drive faster your thermostat is gone. If its jumping about randomly then its quite likely the temperature sensor.
    TD5 Land Rover Defender build
    WHITEY_1's Avatar
    Jan 2006
    S-Wales
    229
    Forgot to post an up date on this . it was the water pump.
    so had the cambelt done as well even though there was 50 odd thousand miles still left on it! So if you have got these symptoms you know it is your water pump! All the best! Oh 1 more thing I put a metal water pump back in not a plastic 1 All the best!
    Jan 2011
    684
    Glad you got it sorted.
    I had my cambelt done recently along with waterpump and I asked Audi to use a metal impeller waterpump and they refused, said it would be plastic....
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
