Chris NottSky Insurance
Results 1 to 11 of 11
    Mar 2011
    RED HOT GLOWING TURBO
    Hello,
    I have a 53plate 1.8t cab, which has had some major issues of late.
    I bought the car as a non-runner and have since fitted a used engine and a new (recon) turbo and a new stat/housing.
    My problem is that the turbo glows bright orange after being driven a short distance when up to temp.
    I have also replaced the cat and tried running it with no exhaust and it still does it, the engine does appear to run hot but does not overheat.
    Its got no faults storred and I have tried running it with the stat removed which doesnt change.
    Please help !!
    Avant4me's Avatar
    The're Graphite not black!!
    Mar 2010
    Bristol
    257
    You had it on VAG Com to check the waste gate duty cycle? sounds like its fully open so all exhaust gas is flowing over the turbo
    Official Fan Club member No 001!!
    Mar 2011
    Ive got vag com can but havnt used it much, how can I check this
    Avant4me's Avatar
    Mar 2010
    Bristol
    257
    Log 118 against 115. THis will give you a comparison about how much boost is being requested and achieved and how hard the turbo is working to generate this. Duty cycle which is the 3rd column is the duty, its a percentage. Anything above 80% would be unusual. Could be that the wategate is stuck.
    Mar 2011
    Hello again, iv checked out the readings and they all appear to be in spec. I have since tried a new turbo unit on it and it still happens. The only fault present is for the brake servo vac pump, but the brakes feel ok. Any ideas ?
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Try looking at your crankcase breather valve - very prone to failure. When mine went it too made my turbo and cat almost see-through it was that glowing! Even after 5minute drives!
    Tyre in Crankcase Breather Valve into the search facility above and look for the threads in the A4 B6 section - it is a very easy, cheap fix 6 for the part and DIY. Worth a try as these go anyway so the worst that will happen is that you have a new valve fitted and another thing ticked of the list of potential causes.
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Quote Originally Posted by CHRIS555 View Post
    PS. If your car slightly wobbles at idle this is a sure sign of the valve failure.
    Mar 2011
    Yes that was faulty I've changed it already, fault is still there !
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,953
    Typically this is a sign of a blocked cat.... But you say you've already changed it.
    Does the car feel sluggish?
    TD5 Land Rover Defender build
    Mar 2011
    No car drives and pulls very well, ive done a bit of digging and the engine I was supplied with has serial number missing and engine code ground off. I did find a part number on the block 06a 103 021c is this the correct engine and the number on the cyl head is 058 103 878a. Could I possibly have a naturally aspirated engine with incorrect compression ratios ??
    "Stick a V8 in it!"
    14,953
    No result for either of those part numbers.
    I spect the engine is in some way dodgy if the numbers have been ground off, probably stolen, or from a CatA write off.
