JMB RetrofitsVolks Autos
Results 1 to 11 of 11
    medicpaul's Avatar
    Feb 2011
    61
    Fitting new bulbs, do i need to remove the headlight?
    The dip beam on my B6 is pretty horrendous, so before doing a full HID upgrade I thought I would try some Osram Nightbreakers. Haven't had time to fit them yet as we have a new baby but does the headlight need removing to fit them???
    2004 A4 advant 1.9tdi B6
    Dilligaf-UK's Avatar
    Chugging along
    Nov 2010
    183
    Yes - or at least I had to last week!
    The Nightbreakers make a hell of a difference!
    2004 A4 1.8T (190) S-Line Quattro
    FULL VCDS - HEX-USB+CAN
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I've heard of people able to do it with the light in situ, they clearly have smaller hands than I do!
    There's a few threads on here telling you how to remove the headlights if you need them.
    medicpaul's Avatar
    Feb 2011
    61
    For some reason I can't find the thread regarding removing the headlight, could someone help with some direction?
    Mar 2008
    Dorset
    13,856
    Use Google as the search feature on here isn't much use. Start off with "Audi-Sport" and then what you're searching for and you should find it.
    Failing that I'll link the diagrams from my Photobucket account when I get home later.
    Jan 2011
    684
    This thread should help - Headlight Removal Procedure required please!!
    I did mine recently, dipped bulbs, Bosch Pure Light. Look up my previous posts and you will see comparison piccys.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,269
    Here you go..try here VW AUDI Forum - VWAF
    Jan 2011
    684
    oh you will need an extenion bar on your socket set to slacken off the lower one(s), my only difficuly was removing the electrical connector, one didnt come out at all.
    Feb 2011
    Whipsnade UK
    94
    On the Cabrio it was very easy to do, still can't believe you have to take the headlight out to change a bulb as I wouldn't want to do it in the dark, but easy nevertheless.
    Just loosen two screws either side, electical connector was a bugger until you figure out how they work.
    I've used some philips extreme and it is ok, but not great.
    Jan 2011
    684
    Cab has just one lower torx to loosten off, saloons/avants have 2 I believe and yes the power connectors are a bugger !
    May also be worth masking off the top of your bumper so you dont scratch it when sliding the headlight unit out...
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Stick on old towel (or new it is your baby!) on the bumper under the loosened headlight - no need to undo the electrical connector, although you may have to cut a cable tie to give you a little cable slack.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
