EM TuningSky Insurance
Thread: Flat battery
    Apr 2010
    157
    Flat battery
    Hi guys,car wouldn't start this morning due to a flat battery.Used a set of jump leads to get it going but now my fuel and temp gauges don't work.Could a fuse have blown and if so where do i find the fuse box on the tdi avant b6 and which fuse do i check?
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Possibly. May be worth having the codes checked.
    I know that a friend of mine had a B6 and his battery just went too - with no warning what so ever
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    side of the dash, open the front door look at the side of the dash youll see that the panel will clip out, fuse box is behind there
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Use your car key to pop the cover of
    Apr 2010
    157
    thanks guys but had to buy a new battery.once this was fitted all the dis faults corrected themselves,including both gauges.
