AH FabricationsChris Nott
Page 1 of 2 12 LastLast
Results 1 to 40 of 58
Like Tree3Likes
Thread: Xenon headlight issue
    Oct 2007
    cork ,ireland
    73
    hey guys,
    My xenon lights are giving me a bit of trouble . I search the forum and i cant seem to find anything on it but forgive me if I missed it . The lights are not adjusting up . I took it to main dealer and the told me that the fault was the adjustment motors .So they were changed and no difference . The are bemused by it . I have orange warning in the dash with a picture of a like a light on low beam . I put my on vagcom on it and got the same fault .
    Any help please
    a4 v6 2.5tdi b6 18"rs rns-e genuine bt quattro chipped to 210hp mfsw,cruise control, ashtray ipod connector,
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,685
    What fault did VAGcom say you had?
    Sep 2010
    Manchester
    60
    This happened to me too (although I didn't replace my motor on Audi's advice). I went to my local Independent and he reckoned it was the ballast pack, so I took a gamble and got myself a new one from the dealers and it sorted all the issues.
    Oct 2007
    cork ,ireland
    73
    It some thing like right adjustment blah blah .....i cant remember sorry
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    946
    The error code will tell you what's wrong so suggest you find out what it was - save you some time!
    The Workshop manuals we can get access to can then give a set of tests to check for the specific fault reported.
    There are two suspension level sensors, one on the front and one on the rear suspension, sometimes the metal breaks on the mount and also the connections break or get dirty - check the connection and maybe worth a clean with some contact cleaner.
    There is a control unit behind the glovebox, and of course a stepper motor in each headlight.
    Test - as covered recently on another thread - I recall... Ignition off, Lights ON, ignition on and lights should move up to correct level position - check both sides - levelling is done at ignition on as opposed to lights on.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Oct 2007
    cork ,ireland
    73
    Ok I will check error code tomorrow .
    But the error code I got was the same as my mechanic got with his snap on diag. and the same as main dealer and the same as my vagcom and three said replace the adjustment motor .
    Thank for your reply by the way
    Do I just remove the glove box and the control unit is there and what about access to the sensors on the suspension are they east to find .
    thanks in advance
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    Did you try the test?
    Item locations indicated below - Note: LHD diagrams so may need transposing to other side.
    Oct 2007
    cork ,ireland
    73
    [QUOTE=Woorlord;1200135]Did you try the test?
    I tried the test and got no joy .
    Now my vagcom is giving me a bit of trouble so I got a loan of a mate's launch .
    This is the fault code .
    Code 01535 R headlight range ctrl positive motor v49 short circuit to earth.
    I put it up on the ramp and check the modules as you showed but to be honest I couldnt see any thing out of place wiring etc. I can tell you that when the fault accured I did have excessive weight in the boot for a long journey .
    Sorry for bumping again.
    26,716
    Curious who www.capav.com are or will be.
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    Quote Originally Posted by quattrov6tdi View Post
    The error code is saying there is a connection problem with the Right Headlight Motor V49.
    I would suggest checking all connections between the Headlight range control unit J431 (behind glovebox) to the actual right headlight motor V49.
    I have highlighted the relevant circuit above in red.
    It is also worth checking the connections at your A-pillar for connector 17c (17-pin RED connector).
    Just done a search in Bentley Manuals on the error number 01535 and there is a Technical Bulletin saying to check the connections - here is a link to a >>screenshot pdf<< of the Bulletin.
    It's a private joke on one of my colleagues at work - it's when he is leaving for pastures new. capav.com is my web domain space where I host my various pictures and info for the forum.
    26,716
    Ahhh thought you had something up your sleeve matey, lol.
    Mar 2011
    East Mids
    452
    Hope you don't mind me joining this thread but my DiS has over the past few days has been flashing up faulty headlight level system. It is on and off though I.e the warning light will beep stay on for a couple of mins then go off. Then back on, off etc.. It's driving me mad (the beeping) been told this is probably a dirty sensor as mentioned above, but have no VCDS to confirm will try cleaning sensors and see how we go
    B6 S4 4.2 V8 SILVER SALOON - BEIGE ALCANTARA - BOSE SYMPHONY - DRILLED/GROOVED FRONT DISCS
    FOR SALE: £6750ono
    Previous Cars
    .:R32 MKIV 3DR Pearl Black (Awesome car), Lexus RX300, Lexus LS400, Mitsubishi Shogun Sport V6, Audi TT Roadster 225, Range Rover Vogue 4.6 V8, Mazda RX8 231, Peugeot 307 CC 180, Subaru Impreza WRX 2.5, BMW520i, Lexus IS200,Golf GTi MKV, Audi A4 1.9TDi 130
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    Quote Originally Posted by Bigrichw View Post
    As mentioned above get a scan and you will then know what's triggering the error - there are many VCDS/VAG-COM owners out there who can help - check out this >>Link<<
    Download the pdf I have linked above - it could be a known connection problem on the control unit behinf the glovebox.
    26,716
    Yeah I would give the connectors on the levelling sensors a once over as maybe got some gunk in there thats corroded a pin or 2, cause even if the arms had broken they dont tend to show an error iirc, just point the light at incorrect position.
    Mar 2011
    East Mids
    452
    Cleaned the sensor contacts today - still showing fault (intermittent) still no movement from lights when performing above test... Cant get my VAGCOM to work keeps freezing up on me. I guess the next check is the controller behind the glovebox -
    FOR SALE: £6750ono
    Previous Cars
    26,716
    Get a genuine vagcom mate, never have issues then :P
    Mar 2011
    East Mids
    452
    OK, I disconnected the isoblock from the control unit behind the glovebox - and it appears to have cleared the fault. Now when the ignition is performed the lights move up.. well they do for now... time will tell... thanks for all your input
    FOR SALE: £6750ono
    Previous Cars
    Mar 2011
    East Mids
    452
    Update: DIS still showing fault - so I went back to the control unit and with the ignition on, unplugged the isoblock from the unit.. the fault cleared, plugged it back in, fault re-appeared, unplugged, fault cleared.. disconnected battery, plugged back in, fault appeared... so I have left the thing unplugged - I can only assume this means the control unit is faulty? Would you agree? - or could it still be the wiring issue? - which I can imagine is a bugger to sort? Also anyone know the part number of this control unit and approx cost?
    (Also posted in another thread\0)
    FOR SALE: £6750ono
    Previous Cars
    26,716
    You need to log the car 1st before rushing out getting new module as it may not be this.
    Mar 2011
    East Mids
    452
    Yes I agree, I am hoping to get it scanned on Friday... In the meantime is this the correct control unit?
    VW AUDI HEADLIGHT CONTROL MODULE HELLA 4B0 907 357 on eBay (end time 15-Apr-11 23:35:35 BST)
    or this one?
    AUDI A6 HEADLIGHT CONTROL UNIT 4L0 910 357 on eBay (end time 09-Apr-11 15:11:25 BST)
    FOR SALE: £6750ono
    Previous Cars
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    or this one?
    Your control unit part number is clearly stated in the >>other thread<< you listed your scan on relating to HID Range control problems, it's also written on the actual unit.
    Headlight Range Control unit: 4Z7 907 357 @ ~190
    Self Levelling Suspension sensor [Rear]: 8E0 616 571 D @ ~110
    Self Levelling Suspension sensor [Front]: 8E0 941 285 J @ ~90
    Price is approx & inc. VAT
    Mar 2011
    East Mids
    452
    Everything seems to be ok with the unit unplugged... Any real reason to fix it? I mean who ever alters the headlight height anyway???
    FOR SALE: £6750ono
    Previous Cars
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    Only that it is a legal requirement for HID headlights.
    Mar 2011
    East Mids
    452
    Quote Originally Posted by Woorlord View Post
    Bogger...I was hoping you weren't going to say that .... Back to the drawing board
    FOR SALE: £6750ono
    Previous Cars
    Mar 2011
    East Mids
    452
    Scan done found 2 fault codes
    00776
    00774
    According to ross tech wiki, bad earth / wiring??
    Anyone can help and shed a bit more light on this?
    FOR SALE: £6750ono
    Previous Cars
    Fossie
    Rhubarb Triangle
    3,961
    And so are headlight washers !! Soon to be part of MOT
  28. #27
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    And the relevance of this with regard to OEM factory fitted HID's is???
    Let's please focus on the problem in hand here and contribute to problem resolution.
  29. #28
    Fossie
    Rhubarb Triangle
    3,961
    Merely pointing out to anyone reading the thread and who may be considering converting to xenons, that as you correctly pointed out, levelling is a legal requirement as are headlight washers. If the questioner didn't know that levellers were a legal requirement (which he clearly didn't ) then no doubt he and lots of others didn't know about the headlamp washers or the forthcoming MOT implications.
    Both are soon to be part of the MOT.
    No need to take that attitude mate - purely pointing it out for the possible benefit of others !
  30. #29
    26,716
    Woorlord I think Mike was merely making a point that he really should address/fix the issue given both these systems are legally required, whereas the OP seems to be indicating he will just leave it as it is, which the mot rules will fail him on when they bring these in, Mike made a fair comment, cant see why you needed to post that tbh mate as I often read your posts & always very helpful & non friction.
  31. #30
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    Like I said irrelevant to fixing the problem in question as this is an OEM factory fit HID issue and not HID retrofit Perhaps relevant in the correct relevant thread?
  32. #31
    Fossie
    Rhubarb Triangle
    3,961
    Fair enough but consider what would happen if the OP took his car in for MOT and it failed.
    At least he (OEM fit or not) knows that if they are not working then it won't pass.
    Still reckon it was worth a mention, whether you agree or not !
    Hope you fix his problem
  33. #32
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    Thanks for the reminder Mike on the Headlight Washers, you do have a very valid point that this too is required to be strictly street legal with HID's.
  34. #33
    Mar 2008
    Dorset
    13,685
  35. #34
    Mar 2011
    East Mids
    452
    00776
    00774
    So any tips for me please?
    FOR SALE: £6750ono
    Previous Cars
  36. #35
    26,716
    Yes, get a used unit & try swapping over if you have checked the sensor wiring on axles, logged into the headlight levelling module ok, checked all associated wiring.
    I would check no wires have been coaught somewhere creating a short of some kind as its strange this comes up as dont see it often & modules are fairly reliable, although I would try another.
    Not trying to sell, but you really do need vcds to track this fault down & also code/test a replacement module anyway, otherwise you'll be on this for more weeks.
  37. #36
    Mar 2011
    East Mids
    452
    Thanks NHN.. I've been trying to locate a module but they are as rare as chicken teeth, either that or I'm looking in the wrong places!! Yeah I'm thinking I need an auto electrician with VCDS to sort it for me. Do you know of anywhere around Nottingham?
    FOR SALE: £6750ono
    Previous Cars
  38. #37
    26,716
    PM me as I would be able to look at this for you if interested & maybe be able to get a module aswell.
  39. #38
    Mar 2011
    East Mids
    452
    Done mate... thanks
    FOR SALE: £6750ono
    Previous Cars
  40. #39
    Mar 2011
    East Mids
    452
    Update: I managed to get a VCDS scan done and these are the results:
    Tuesday,12,April,2011,15:37:19:26365
    VCDS Version: Release 805.1
    Address 55: Xenon Range
    Control Module Part Number: 4Z7 907 357
    Component and/or Version: dynamische LWR D09
    Software Coding: 00060
    Work Shop Code: WSC 63351
    1 Fault Found
    00776 - Level Control System Sensor; Left Front (G78)
    31-10 - Open or Short to Ground - Intermittent
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 Q
    Component: ABS/ESP allrad 3032
    Coding: 04595
    Shop #: WSC 06435
    1 Fault Found
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-10 - - - Intermittent
    It would appear fault code 00774 is no longer an issue!
    So does this mean there is a bad earth from the front sensor to the module???
    Also is the other fault code anything to worry about?
    FOR SALE: £6750ono
    Previous Cars
  41. #40
    Oct 2007
    cork ,ireland
    73
    Thank for all the info above .
    I have checked all the wiring and connections and all is ok . I have disconnected the module behind the glove box and the fault is cleared but the lights are in the same position .
    I have not reconnected it yet .
