Sky InsuranceChris Nott
Results 1 to 40 of 40
Thread: Diverter valve
    Alan H's Avatar
    Need a V8 or Bi-Turbo.......
    Aug 2010
    Dudley, West Midlands
    453
    Diverter valve
    Hi all,
    Can a dodgy dv cause a drop in power?
    I have the 1.8T 163..
    The reason I ask is when I'm on about quarter throttle the car seems to really pull wel, but when I put my foot hard down the car seems to run more like a normally aspirated car rather than a turbo...
    I hope you guys get what I mean.
    TIA,
    Alan
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    If you have a faulty DV it will effect the power for sure.
    Alan H's Avatar
    Aug 2010
    453
    Quote Originally Posted by docurley View Post
    In the way I've described?
    I know it's not the MAF sensor because I changed that some months ago (genuine BOSCH)
    Sometimes the car feels like a bloody flying machine, but then sometimes it feels lethargic....
    It's hard to explain.
    Plus it's not flagging any faults....
    Alan
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Could be a faulty N75 or a loose/break wire to the N75
    Alan H's Avatar
    Aug 2010
    453
    N75?
    What's that?
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Controls the boost.
    Alan H's Avatar
    Aug 2010
    453
    Thanks very much....
    Are they pricey to replace?
    Where are they situated?
    Thanks,
    Alan
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    There quite cheap and they are located depending on what 1.8T next to the DV which mounted on the turbo intake pipe if a 190bhp then the DV is mounted under the car by the drivers fog light.
    Alan H's Avatar
    Aug 2010
    453
    It's a 163bhp....
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Then the DV will be mounted next to the N75 which will have a plug connected to it and two small pipes feedingoff it while mounted in to the intake pipe.
    Alan H's Avatar
    Aug 2010
    453
    Thanks for all the replies docurley.
    Looks like a job for the weekend....
    I will disconnect it and see what happens....
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Also check all the vac line just in case.
    Q4
    Oct 2008
    33
    Good luck in finding the cause, when you do find it please let me know what it was as I have had this problem for a while and after much money spent with diagnosis and component replacement I have not yet got to the bottom of it!
    For info the car shows no engine error codes what so ever. Go figure !
    So far I have replaced DV, MAFF (twice), N75, coil packs, spark plugs, vac pipes, secondary air valve, both vac solenoids, fuel pump, fuel filter and intake temp sensor.
    My hesitation/flatness comes in around peak boost 3100rpm ish and goes at around 4k rpm. So far its been tracked down to the engine detecting pinking/Knock and then retarding the ignition timing hence the feeling of the car going flat.
    What has not been deteremined is the cause of the knock in the first place. Some theories are blocked intercooler causing high intake temp or intake pipe collapse or possibly dual mass flywheel breaking up causing vibration down the crank that is picked up by the knock sensors. No one has been able to say for sure the cause of the problem and the next "try it" options are starting to get expensive.
    Well good luck in finding the problem if you do find a cause then I would appreciate knowing what the problem was for you.
    If you need anymore info on my experiance just drop me a pm.
    Regards.
    Alan H's Avatar
    Aug 2010
    453
    Quote Originally Posted by Q4 View Post
    Regards.
    That is not good...... :-(
    I'm going to try the N75 valve first.
    Do GSF or ECP do these or is it a dealer only part?
    TIA,
    Alan
    Feb 2006
    Lincolnshire
    722
    Alan,
    I have a similar issue on mine, though only since remapping. It pulls really strongly on part throttle, but full throttle and it hesitates a little around 3 to 4k.
    I changed the DV, and no difference, though my old one was tired anyway. Next I tried a new N75 valve and chose the J version that is much talked about on here. It was a dramatic difference, the car felt so lively and pulled hard with no flat spot. I was very pleased!
    Alas, the full throttle hesitation returned a couple of days later, and also the car seemed to almost have a bad misfire even on part throttle. I put the old N75 back on, and normal service was resumed.
    So, I ordered a standard N75 from the dealer which has been upgraded over the years, and the hesitation was much improved.
    I've recently changed from Esso fuel to either Shell or BP, and the hesitation is now gone. I had to refill with Esso just last week, and my hesitation is back! Might be of help to you, might not!
    I changed all the coil packs, spark plugs and renewed all of the vacuum lines, two of which were split, before I started looking at the valves and I'm sure all that helped too.
    I think the N75 is a dealer order only, there are so many variations on it, your reg is the safest bet for getting the right one.
    Happy to lend you my 'J' valve for elimination purposes if it will help, but my engine didn't like it at all!
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Alan H's Avatar
    Aug 2010
    453
    Quote Originally Posted by Tooks View Post
    Alan,
    Thanks Tooks....
    Does anyone have any part numbers at all? GSF have 2 options, would it matter which one I put on?
    Feb 2006
    Lincolnshire
    722
    N75 'J' - A034 906 283 J - 51.40 + VAT
    N75 'E' - 06A 906 283 E - 36.70 + VAT
    My car is a 2002 model year 1.8t Sport quattro, part numbers are from invoices from two Audi dealers earlier this year, so should be current.
    The J valve is meant for an Audi S2, so the t piece pipes are the wrong way round for your car, so you need to turn it upside down. It sounds more difficult than it is, whichever one you buy just make sure the longest t piece goes into the same pipework as the valve you remove and you'll be good.
    Fingers crossed for you!
    Alan H's Avatar
    Aug 2010
    453
    the part number on mine is 058906283 then a "c" stamped into the metal.
    does that make sense?
    I just phoned GSF and they didn't recognise the part number.
    Feb 2006
    Lincolnshire
    722
    Quote Originally Posted by Alan H View Post
    That's the same part number as my old one, it has been superseded by the E valve detailed in my post above.
    Alan H's Avatar
    Aug 2010
    453
    gsf didn't recognise that either.... :-(
    Feb 2006
    Lincolnshire
    722
    Yeah, they don't seem to be very good with some of these parts, which is why I ended up going to Audi for one.
    For the sake of a tenner or so, I thought it worth it.
    Alan H's Avatar
    Aug 2010
    453
    That's exactly what I've just done. 44 including the VAT and 10 minutes for me to fit it.
    Going out in a while so I'll see if there's any difference.
    Feb 2006
    Lincolnshire
    722
    Excellent!
    Look forward to the report back!
    Alan H's Avatar
    Aug 2010
    453
    Plus the breather filter thing that sits above the n75 had a bit of gunge in it so I cleaned that out too...... it all helps.
    The trouble is I've got nothing to compare the car to, so I never know if it's performing properly :-(
    Wiil report back later on today......
    Alan H's Avatar
    Aug 2010
    453
    OK, just got back from doing a bit of running around and changing the N75 valve seems to have done it....
    It's not placebo effect either I've been very subjective with it and I can actually feel it trying to pull when my foot is hard down, whereas before I changed it the car just felt like an NA car.
    I'm not getting the slight surges (at very low throttle) either now that I was getting before.
    So hopefully this has sorted the issue out, but I will monitor it for a week or two first before giving it the full thumbs up.....
    Hope this thread is of some use to others
    Feb 2006
    Lincolnshire
    722
    Good news!
    Fingers crossed it stays sorted.
  28. #27
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Nice to here your sorted.
  29. #28
    Alan H's Avatar
    Aug 2010
    453
    I couldn't really tell earlier on because I was 5 up with the shopping.
    Just popped out with just the Mrs and I think I can say it's well and truly sorted. It's like a completely different car. I had to back off a bit, because I was still driving it like I was before and there was no need to......
    Next stop ....... re-map....
  30. #29
    Q4
    Oct 2008
    33
    Thats good news Alan, best I try another N75 then.
    Please lt me know in a week or two if it's still sorted the problem.
  31. #30
    Alan H's Avatar
    Aug 2010
    453
    I will report back. It has made such a difference to my car. When I got the car I was a little disappointed to say the least, but I got used to the low performance of the car and thought, well, I'll know not to go for another car like this.
    Having changed the MAF and now the N75 I have a renewed interest in it. But I want a re-map on it now, I want that extra bit of ooomph........
  32. #31
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    In short Badger5 is your man, pm the guy for your remap.
    AUDI A4 190T S-LINE.
  33. #32
    Alan H's Avatar
    Aug 2010
    453
    Thanks CMD, has he got a website or anything?
    found it......
  34. #33
    Feb 2006
    Lincolnshire
    722
    I must admit, since I had mine remapped, I've fallen in love with the thing!
    I can toddle around town in it, waft along country roads, but when the mood takes or I need to overtake, it's a bit of a beast!
    Yes, I'm always tempted by the prospect of owning something much faster like an S4/RS4, but back in the real world I'm a happy chap.
    Two other things that I've noticed since the remap is the sound of the turbo working, and I get a couple of extra miles per gallon.
  35. #34
    Alan H's Avatar
    Aug 2010
    453
    I can imagine with around 200 bhp mine would be quite exciting too.......
    Might be a couple of months before I get it done though, winter has taken it's toll on the house and garden..... :-(
  36. #35
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    found it......
    His website is sooooo old but belive me when i say this guy knows is coconuts.. 1.8T are is specialty.
  37. #36
    Feb 2011
    littleborough lancs
    236
    now this has got me thinking??
    i have just got a 1.8t cab, i love the thing , but i wouldnt mind a little more omphhhhh!
    yeah its fast inough, compaired to the 2.0i (130 bhp) i had prior to it its a hole new ball game
    woudl sticking a new n75 on it make a big improvement?
    ohh, the other thing is,,, i know this sounds silly but, what duz everyone else's turbo sound like, mine duznt have a wistle sort of noise( like on my old supra) insted it more like a raped fire pee shootre sound, lol i know its sounds like a dafe example!! but its like a tih tih tih tih tih noise,( crap at sound fx)
    is this normal
    seems to work fine???
  38. #37
    Alan H's Avatar
    Aug 2010
    453
    First thing to check is the MAF sensor. Disconnect it, then drive the car....you'll get the ESP light come on, but if it's the MAF you'll tell because the car will feel and pull loads better. Once you re-connect the MAF after a short while the ESP light will go off. (you will have a stored error code though, so you may want to get it cleared)
    A new MAF from GSF is about 60, but it's an exchange unit so you have to pay a 30 surcharge which get's refunded when you take the old MAF sensor back.
    This is an easy fix and takes about 20 minutes.
    I hear my turbo spooling up from about 2000 rpm
    Changing the N75 valve does make a difference if it's that that's broken....but my suggestion would be to get it on VAGcom to see if there are any other faults before parting with 45 for the N75 valve.
  39. #38
    Feb 2011
    littleborough lancs
    236
    I think everything is working fine, i had the maf go on a b5 a4 a long time ago, n yeah, it duz make the car run like a old dog when they go, but mines ok,
    just whanted to know if the n75 would make the car more poke-ie, & how everybodys turbo sounded,
    mine kicks in at about 1800-2000 rpm, then the car realy wakes up, but i havent come across one making a sound like mine is , altho this is the first audi turbo i have owned,
    think everything is working fine, nothing opos up on my coad reader and the cars running fine
  40. #39
    Alan H's Avatar
    Aug 2010
    453
    If the N75 valve is dodgy, then it WILL have a detrimental effect on the cars performance, it will make the car lose boost. Mine was fine at part throttle, but put if I put my foot hard down there was nothing. It was like driving an NA car, no boost at all. The solenoid gets tired. It might be worth a punt just changing it anyway for the sake of 45
  41. #40
    Feb 2011
    littleborough lancs
    236
    thanks, i may give it a go,
    still loving the car too much yet to get started with the plans i MAY have for it??? watch this space tho lol
