Chris NottSky Insurance
    Jan 2011
    Gainsborough
    68
    Ambient Lighting
    I've noticed a lot of you folks have this as a mod. I presume this is a couple of LEDs that shine down from the interior light to illuminate the gear lever etc?
    Firstly is it a cheap mod and I presume you change the whole interior light unit?
    Secondly do you need to wire up anything separately, I presume that the LEDs are fed from the same cable that illuminates the switches.
    Thirdly I've seen people mention rear ambient lighting. Is this for the saloon or avant?
    Thanks in advance
    simon.m's Avatar
    Oct 2009
    2,746
    hi mate its cheap to do you buy just the LEDs no need to change the hole thing as it has the markings on the back for you to drill out about 10.pounds from audi i think the wiers also have the spaids on them so its plug and play
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Look here where all your queries will be answered!
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    There are loads of threads on this.
    A rear lighting thread is here:
    A4 Avant - Rear ambient light installation.
    8E0 919 063 A is the part number required.
    There's lots of thread for fitting the front ones, basically just split the light and pop in the led's. I'll have a look for a guide a bit later if no one else posts it.
    Mar 2008
    Dorset
    13,856
    Pipped at the post
