Volks AutosAH Fabrications
Thread: GT28 on 1.8 avj
    Feb 2011
    North Wales
    71
    GT28 on 1.8 avj
    Has anyone fitted a gt28 to a 1.8t avj? and a rough idea on how mutch the upgrade would cost
    thanks
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    You would be best to look on Audizine.com for info on BT on B6's.
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Check this out:
    :: a4mods.com :: - The Premiere Audi A4 Modification Guide and Pictures Library
    Have a good look across the site - YOU WILL find it very useful!
    Also, speak with Backdraft Motorsport, Milton Keynes - they do GT28 Conversions for our car
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,320
    As a rough guide of the bare minimum required:
    excluding the cost of the turbo itself, your talking $400ish for a manifold, and $250ish for a kit with all the oil and coolant pipes for the turbo
    You will then need a downpipe with a T25 flange on it, these can be had for around $300 in a fitment that will bolt up to your existing exhaust.
    Some tweaking of the intake pipe is probably needed, and then you'll need a map which is going to be at least 400.
    I recon starting with a standard car, and doing a lot of the work yourself, you're looking at around 1500 just to get it running.
    Ideally, your going to want to put a bigger intercooler on, and probably change the exhuast out for something better, so will need to spend a bit more. You will also need a set of injectors and probably a 3" MAF housing if you want to get decent power from it.
    Could easily spend 2k+ if your starting from a stock car, although shopping around and buying used etc where possible could see that dropping down a bit.
    TD5 Land Rover Defender build
