Results 1 to 8 of 8
    Jun 2009
    Co.Cork, Ireland
    20
    Brake light switch question
    On Sunday I was driving along and the ABS & traction control lights came on. Stopped the car and started again and the lights persisted. About 10 minutes later the glow plug light came on and was flashing. The brake lights also weren't working. It persisted for the day. Consulted the site and it said the brake light switch needs to be changed.
    On Monday rang around a few Audi garages and found one with the part. Off I went and bought the part. Sods law being as it is on the way home from the garage the lights went off and the brake lights were working again!
    Should I change the part anyway or is it OK to go on as it is?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I'd change it if I was you, being as you've got the part as I'm sure it will go again.
    I can send you a pdf guide if you want it, will need your email address.
    Mean Green Machine
    Mar 2011
    Co. Clare, IRELAND
    21
    i have a 2002 avant sport, i suppose the set up should be the same???? could you fwd the pdf of how to replace please, many thanks..
    timaisling@gmail.com
    2002 A6 Avant Sport 130 BHP TDI
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by tullA6 View Post
    I've sent this, did you get it?
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    I would definitely replace it. its easy to do. take the cover off below the steering wheel, unplug, twist, pull out and the reverse to install. Whilst you are there it may be worth doing the clutch switch. Have replaced them both on my 2003 avant
    2.5 tdi Quattro sport - PhatBox - DIS - Cruise - RS4 ARB - Remap - and a few other minor mods/retrofits
    2.0 TFSI A4 b7 cab - completely std for now... (the wife's car)
    Dec 2009
    19
    Hi, would you be able to send me the pdf for replacing it too? my emails mark.williams82@hotmail.co.uk
    Jan 2012
    Hi, would you be able to send me the pdf for replacing it too? I have the switch, and any help would be gratefully received, my emails tsjagpal@yahoo.co.uk
    Thank You
    Dec 2008
    32
    Hi! I have to replace my A4 Avant B7 Brake light switch. Grateful for a copy of the procedure. E-Mail is albarker01@btinternet.com Thanks in advance
