Tooks
Ok, got another little issue with my car.
Basically, the fuel gauge seems to have a mind of its own.
Parked up last night, 1/4 tank showing, roughly 90 showing on the DIS fuel range display. Started off this morning, nearly full showing on the gauge (I hadn't added fuel!), but DIS range showing the same.
Filled up later today as DIS range had been counting down to 0 as normal, fuel gauge showed over full, ie right over to the far side as far as it will go. DIS range showing 410...
I've noticed with the ignition off, the fuel gauge needle still says approx 1/2 full, it should be zero shouldn't it?
So, do the gauge and DIS fuel range take info from the same sender? I understand there are two in the B6?
Do I suspect a faulty gauge/dash module, or could it still be sender related?
Any ideas?!
Any ideas?!
