Chris NottVolks Autos
Results 1 to 13 of 13
    Dec 2010
    220
    Would 5x110 offset alloys fit a b6?
    sorry more stupid questions do you reckon 5x110 alloys with et43 would fit the audi thanks
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,372
    not without wobble bolts and appropriate spigot rings.
    Dec 2010
    220
    Ok so its possible then with the bolts and rings then?thanks
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,751
    5 x 112 wheels with the correct offset really aren't that rare! I'm not sure why you're trying to fit such abnormal wheels!
    Dec 2010
    220
    Lol,just want to see my options before i spend a big wad of money thats al.....l maybe something different as well
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    Our A4 b6's have the following 5x112 stud, 57.1 center bore , Offset 43-35. Stick within these guidelines and you should be fine.
    AUDI A4 190T S-LINE.
    Aug 2009
    833
    Wobble bolts are your friends , I'm assuming astra wheels?
    Dec 2010
    220
    Well was thinking vectra c ones ,but might still go for the s4 17s presumably they fit straight on
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    S4 17s will fit straight on
    i would like to see a set of 10mm hubcentric spacers on the rear at least for a bit more stance thou.
    Dec 2010
    220
    Sounds good ,expand on the hubcentric bit as youve lost me lol
    matttrs's Avatar
    Mar 2010
    164
    hubcentric sit on the flange of the hub, making sure they are perfectly centred, they again have a hubcentric lip for your wheels to sit on, so everything sits in the middle of the circle.
    On older spacers for old dubs and other cars, you'd often get wheel wobble from wheels not sitting perfectly central
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    All spacer's should have hub centric fittment. In a nut shell it's the center of the wheel (hole) sit's on a lip which is 57.1. examples below
    NOT HUB CENTRIC.
    Grayston Universal 4 Hole Wheel Spacer 10mm on eBay (end time 16-Feb-11 20:39:13 GMT)
    HUB CENTRIC
    10mm wheel spacer kit Golf Mk3/4/5 A3 S3 A4 S4 RS4 NEW on eBay (end time 17-Feb-11 11:19:59 GMT)
    If the spacer's are NOT hub centric you will suffer wheel wobble.
    Dec 2010
    220
    Ok thanks matt,maybe would look nice with the back wider mmmm
