EM TuningMonster Motorsport
Page 1 of 2 12 LastLast
Results 1 to 40 of 44
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Puddle/warning light fitting guide
    After the success of the guide for fitting puddle and warning lights on the A3 (My DIY guide for Retro fitting Puddle Lights) i have decided to do a guide for the A4 which is for the B6 and B7 models.
    Points to note:
    - Vagcom is not needed, the puddle and warning lights do not need to be coded on the A4.
    - Door card clips are very brittle so they can break when removing the door cards, these can be bought from Audi cheap incase they do break.
    Firstly you need to remove the doors cards.
    On the front doors you need to remove the door trim (this pulls off and slides forwards) which gains you access to the 3 screws, remove these.
    Remove the cover underneath the door handle (this is only on the drivers door, the passenger side has 2 screws under the door handle).
    Remove the 2 screws underneath this.
    Remove the screw from the bottom of the door card.
    The door card will now pull off.
    Remove the door handle pull cable connector from the door card and the electrical connections from the door controller and the speaker.
    Now you will need to create the hole for the puddle light, i use a drill to make lots of small holes and then a file to clean the edges up.
    The red plastic reflector on the end of the door card can be popped off and the warning light fitted into its place.
    Now to the electrical part.
    Remove the pink plastic part of the connector by sliding it down. This will allow you to pull out the connection block.
    Now to fit the loom.
    Supply to the lights comes from pin number 13 (Post 07 May cars supply is pin 16).
    Now the earth wire needs to go into pin 21 however this is already been used by the window switch therefore it needs to be shared.
    Remove the existing wire out of pin 21 and solder it to the wire on the loom.
    Push the wire into pin 21.
    Connect the other end of the loom to the puddle and warning light. You are now ready to refit the door cards, ensure that you refit the door handle cable and electrical connectors.
    Check that the lights are working, on a 2003/4 A4 they worked straight away however on a 2006/7 A4 the following step was required to get them working:
    Remove the passenger side sill cover (marked in red), this pulls up as it is clipped on.
    Then remove the plastic side piece which the sill cover is attached to.
    Behind this plastic cover you will see a bunch of electrical connectors, you need to disconnect the black connector (furthest one away from you) and then reconnect it up. This resets the control module allowing the lights to work.
    Thats job done for the front doors.
    The rear doors are very similar, remove the door cards by removing the door trim and removing the screw underneath it and also the screw underneath the door handle.
    Remove the door card and drill the holes for the puddle lights in the same way as the front door cards.
    Now remove the small brown cover from the door controller connector.
    The supply for the lights is pin 2 and the earth is pin 6, the earth does not need to be soldered as the pin is already free.
    Refit the brown cover.
    Connect the looms up to the lights.
    Refit the door cards.
    Pull the rubber cover from the B pillar door connector.
    Disconnect the plug from the car and reconnect it, the lights should be working now.
    Here are the results!
    If anyone is interested in this retro fit i can supply the looms and also can fit these to you car if required, please pm me for details.
    Apr 2009
    Coventry
    2,219
    couldnt you piggyback them onto the wiring for the red door lights?
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    do you mean the red warning lights?
    if so then if you have those then you should have the puddles lights as they were part of a lighting package.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I have door marker lights but no puddle lights....
    Nice guide Robin, thanks for taking the time to post it.
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    Me too, looks like the puddle lights will be even easier to wire up
    2.5 tdi Quattro sport - PhatBox - DIS - Cruise - RS4 ARB - Remap - and a few other minor mods/retrofits
    2.0 TFSI A4 b7 cab - completely std for now... (the wife's car)
    mattyboyc's Avatar
    Sep 2009
    1,224
    Quote Originally Posted by JimLoskot View Post
    Me three, door lights,no puddle lights (yet)
    A4 AVANT 1.9TDI 130 SPORT:
    18" RS6'S//TWIN EXHAUST//ALLARD EGR DELETE//AERO WIPERS//B7 KEYS & ENGINE COVERS//BLACK OPTICS //FRONT & REAR S-LINE BUMPERS//TAILGATE SPOILER//S4 HEADLIGHTS,GRILLS & DOOR BLADES//RS4 RARB & PEDALS//FRONT,REAR & FOOTWELL AMBIENT LIGHTING//PUDDLE LIGHTS//FAN JETS//MEDIA SYSTEM//T.V//7" HEADREST MONITORS//REAR BLINDS//REVERSE CAMERA// CRUISE & DIS
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Can people who say they have the red warning light please check if this lights up when you open the door, it seems odd that you have the red light but no the puddle lights as they run off the same loom. The red 'light' is usually a red plastic cover with no bulb behind it.
    Mar 2008
    Dorset
    13,856
    Lol no it's definitely a red light!
    I've heard before that it comes as part of an interior light package, but I had to retrofit the ambient LED's too. Mines a 2003 model, I think more of the later ones seem to come with reflectors instead of marker lights.
    simon.m's Avatar
    Oct 2009
    2,746
    mine defo light up mate but no puddle lights ;-(
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    deffo have the red ones but no puddle lights, was this standard on the 6 cylinder models like rear electric windows?
    Mar 2008
    Dorset
    13,856
    Simon's is a 1.9 TDi.
    simon.m's Avatar
    Oct 2009
    2,746
    hey now no need to name and shame like that lol and its a sports lol
    Mar 2008
    Dorset
    13,856
    If I'd wanted to name and shame I'd have mentioned it's a 100.
    simon.m's Avatar
    Oct 2009
    2,746
    ah you mofo lol its a sport to though lol
    mattyboyc's Avatar
    Sep 2009
    1,224
    Quote Originally Posted by RobinA3 View Post
    100% lights on all 4 doors and tailgate
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by simon2004 View Post
    Its a contradiction in terms though, a bit like a Veyron Bluemotion.
    simon.m's Avatar
    Oct 2009
    2,746
    its still a sports though grummble grummble hehehehehe
    Widemonkeys's Avatar
    Aug 2010
    Durham, Durham, United Kingdom
    274
    I've got lights on all 4 doors and the bootlid but no puddle lights, I'll be doing these in the next few weeks
    02 A4 B6 1.9tdi Avant sport 130bhp, 18" RS4's, Cruise control, Armrest, Ambiant lights, LED number plate bulbs,Pressed number plates, rear RS4 ARB, blacked out grills.
    Wanted : S line front and rear bumpers , S4 lower grill, s4 door blades
    simon.m's Avatar
    Oct 2009
    2,746
    so just asked audi about the puddle lights they say they did not start to fit them till late 2003 to 2004 so the would be why some have just the red ones maybe ;-)
    Aug 2010
    274
    What parts do I need and part numbers ?
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Part numbers are as follows:
    white puddle light - 8D0 947 415 - 7.50
    red warning light - 6Y0 947 411 - 10.50
    you'll need these lights and a wiring loom to go from the door controller to the lights which i can supply.
    simon.m's Avatar
    Oct 2009
    2,746
    hi robina3 the loom you on about will i need this if i have working red warning lights already
    will89's Avatar
    Jul 2010
    362
    We're the tailgates on the estate always fitted with red lights and never just reflectors? Mine never used to light up until i took it out and put it back in. I have only got reflectors on the doors though...
    will89's Avatar
    Jul 2010
    362
    The connector shown here is it behind the door card?
    Does anyone also have the part numbers for the puddle lights and for the marker lights?
    Thanks.
    Mar 2008
    Dorset
    13,856
    Part numbers are in post 21.
    will89's Avatar
    Jul 2010
    362
    Another question, where can i get the pin connectors to solder on? If i could find these then i can do the wiring myself
  28. #27
    will89's Avatar
    Jul 2010
    362
  29. #28
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    without seeing your existing loom i can't say if i can piggy back onto it, i could really do with a picture of your current loom to see if could piggy back onto it.
    the only thing i can say without looking at it is my looms will work by means removing the existing pin which currently feeds the red light and plugging my loom in however i am not keen on this as i would like to find out if your current loom can be modified to run the puddle light as well.
  30. #29
    Feb 2011
    10
    I have got the warning light but they dont light up. I havent looked to see if they are just reflectors. Robin, Can i buy the who lot from you so i can plug and plag? How much do you charge?
  31. #30
    simon.m's Avatar
    Oct 2009
    2,746
    thanks mate ill try get a pic of it at some point
  32. #31
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    I can do you a kit to make it plug and play however you will need to do a bit if soldering. Pm me if you are still interested.
  33. #32
    simon.m's Avatar
    Oct 2009
    2,746
    ill get the door card off soon mate and pm you ;-)
  34. #33
    Jan 2011
    7
    hi again robin.
    just a quick post regarding your looms and lights.
    if anyone is thinking of fitting these,then robin is defo your man.
    excellent quality looms and a nice fella to deal with.
    the door lights look superb and add that bit of class.
    thanks again robin for all your help fitting mine,
    sorry about the weather last weekend, but the results were well worth drenching....lol.
    keep in touch,
    Alan.
  35. #34
    T0m
    Sep 2007
    Lichfield
    458
    Hear hear Robin also did mine top job!!!
  36. #35
    boya's Avatar
    Aug 2009
    consett county durham
    394
    Great guide! Pm sent regarding looms Robin.
  37. #36
    boya's Avatar
    Aug 2009
    394
    I fitted my puddle lights today in my 2003 a4 2.5 tdi. The red warning lights were already factory fitted so I just tapped into the loom for them, I needed to unplug the rear doors via the B pillar to get the rears to come on.
  38. #37
    Mar 2008
    1,053
    i did this at the weekend and all for a fiver ..i went to scarpyard cut off a 32 pin block for the pin connetors i needed and got puddle lights and footwell from a passat (all the same) door maker red lights came from a4 b6 would of cost about 65 ish pound from audi
  39. #38
    Jan 2011
    durham
    256
    ivv got puddle lights an dont see the point of them on my avant sport got footwell lights too oh yeah and the armrest lights up when you lift the lid! got no cruise or dis tho rather have this any day!
  40. #39
    Jan 2011
    7
    hi robin,
    any news on fitting the footwell lights on the b7 avant.
    regards,
    alan.
  41. #40
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    if you have the red door lights and no puddle lights then with the door card still on pull the red light out and piggyback a wire onto the earth and positive wires on this light, then cut out the blank for the puddle light and with a piece of stiff wire poke it through the puddle light hole so it comes out of the red light hole as its only 8 inch away and then pull back the wires you have just fixed onto the redlight wires, attach to puddle light bulb holder push into the door and job done. No messing about with looms. Of course this wont work unless you can feed the wire through. i am going to try this on sat so will let you all know if it can be done.
