what number fuse is interior light on an a4 cabriolet ive looked on the panel tellin you what fuse dose what but it do tell you witch one is interoir light ... i wanna tap into this for footwell lights
Interior Lights are fused through the "convenience module" - these are labelled on the sticker on the back of the fusebox cover.
Read this which tells you how Footwell lights should be installed the correct way as per OEM spec. - you can then decide on any shortcuts which may work for you to re-wire them?
