where will i find the wire to connect to so my footwell lights come on when i open door and go off when i shut it ... wont wanna use vagcom i wanna cheat and do itthe easy way .. witch fuse is it so i can join on to a wire there ????????
thanks for the help thenThere is never an easy way - just the right way!
Perhaps you should buy a new multimeter and work it out?
Based on the Interior Light connector and if you want the footwell lights to come on with the interior light then use Pin 3 (red/yellow) [+12v feed mentioned previously] and Pin 10 (red/white) - these connections are effectively across the Interior light bulbs of the roof light, so run these to all your footwell lights. ????????? i dont follow this use pin 3 ? where is that found
is the wire im looking for behind the glove box ??????????? please help im lost
Woorlord would it be quicker and easier if you just went and did it for him?
yeah thanksMake sense now I've sent you the circuit diagrams for the Comfort System?
