AH FabricationsSky Insurance
Results 1 to 12 of 12
    Lancaster
    1,654
    2.5 TDI fuel bleed off pipes.
    Even ladies and gents.
    When I was changing my oil the other day, i inspected my bleed off pipes from the glow plugs. They looked abit soaked. My car is abit hard to start after it's been sat. I read this can be leaking bleed pipes. I beleive they're just push fit piping. Is this true and where woudl you normally get it from?
    Does it sound worth changing?
    To do: None yet.
    Sep 2010
    167
    Hi , yes ive done many for poor starting and its normally the leak off pipes. they are just push fit , you can get them from a local motor factors, tps, dealers, i think it comes in a roll from tps and you just cut them to size.
    Lancaster
    1,654
    Cheers bud.
    Could this effect mpg?
    To do: None yet.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,751
    I'll second what Tony says, a leak in there will allow the diesel to drain back and introduce air into the system, causing starting issues.
    I don't 'think' it will affect mpg, but its a cheap fix and worth doing.
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,715
    Quote Originally Posted by quattro tony View Post
    what he said, +1
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    t the risk of being stupid, where abouts are these? have been looking to check if mine are ok but I see no pipes from the glow plugs
    2.5 tdi Quattro sport - PhatBox - DIS - Cruise - RS4 ARB - Remap - and a few other minor mods/retrofits
    2.0 TFSI A4 b7 cab - completely std for now... (the wife's car)
    Mar 2008
    Dorset
    13,751
    They're from the injectors not the glow plugs. Small rubber pipes maybe 8 or 10mm diameter linking from one injector to the next.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,209
    If the injectors are moist around them then they will need replacing. When i did mine there was diesel running from them and the smell was noticable. However just to throw a cat among, i have never had any starting issues even when the pipes where perished. first time every time.
    Lancaster
    1,654
    I didn't realise they were the injectors, Christ I'm being dim with this car.
    Where abouts are the glow plugs on the 2.5 tdi?
    Cheers Gents.
    To do: None yet.
    Jul 2007
    London
    3,091
    On the side of the heads with them black connestors fitted to the ends...Use plenty wd40 a few days before to ease them off as they known to snap in the head if forced...
    FOR SALE:
    Jul 2007
    766
    Did the pipes on the o/s bank because the was fuel leaking .The old ones seemed hard and had to be cut off the connectors but the other side seems dry so left these.Perhaps the heat affects one side more than the other or maybe someone had already done the n/s bank.Cant see why this would affect starting made no diff that I could see but suppose it must save a tiny amount of lost fuel
    Lancaster
    1,654
    If they leak, the fuel leaks out. Air goes in and you have to crank for the fuel to return.
    I'll get mine done, and have a look out for the glow plugs.
    Cheers lads.
    To do: None yet.
