I'm wanting to upgrade my Avant B6 sport ( 3 spoke wheel) (with retrofitted DIS and Cruise) to a B6 Wheel with radio controls ( 3 spoke ). Do i need to upgrade any modules or slip rings ? Tried searching but most discussions are B6 to B7.
Depends on what steering wheel control module you have, there are 3 types, normal, normal+dis and normal+dis+multifunctionsteering wheel. You need the latter.
Also need some coding changes on vag-com, not sure about anything else.
I upgraded the SCM when adding Cruise, I had 2 letters to choose from, I think it was the later (R) . Would this do the trick ? Do the steering wheel controls plug into this ?
It's not what i'd generally call a MFSW, it just controls the radio etc. Anyways, bought it now, here Will see if it works when I get it. Fingers crossed.
I checked ETKA too. It's looking the same way...
I got an email from the seller with more detailed pictures before he posts it to me, it does look like + and - , but they do look slightly different to the ones in ETKA. He's going to check what car it came from.
Has anyone seen a 3 spoke from a B6 with radio functions on it ?
Deffo tiptronic steering wheel, had the same wheel fitted to my cab before upgrading to B7 mfsw
was never a three spoke (sport) wheel for the B6 with radio controls only the 4 spoke type
