Ok so i apologise about the layout but i'll write it as i remember
So first sign of probs were:-
ESP light would come on solid on dash, climate control would cut out(although windscreen blower on unit will work and bring back on all climate control lights then obviously go off when you turn blower off) , dash backing lights would go off, indicators would not show on dash but would work fine ( no clicking noise neither). This was an intermitent fault at first as ESP light would go off and all fine. Then became perminent
(replaced brake switch light as again some threads led me to this) no success.
Then the other day doors stopped opening with remote
I have replaced the battery with a Bosch.
Made no difference.... alarm triggers, remotes inactive, had to remove siren.
Hazards still flash double time when battery connected, can't turn them off making the car undrivable.
The car starts runs etc so not affecting immobiliser/fuel pump etc...
Even tho indicators constantly flash double speed if you turn indicator on it will work on outside slowing indiucator flash to normal
Other faults i have found obviously all related....
Total closure innactive( from key fob and door lock) central locking ok off door lock.
one touch window closure innactive
Computer will not cycle thru on stalk
Radio does not turn off now when removing key from ignition(happened same time as remotes becoming innactive)
Even tho indicators constantly flash double speed if you turn indicator on it will work on outside slowing indiucator flas to normal.
I have checked the ecu compartment ensuring it is sealed/Pollen filter too, Checked for wetness in loom, drivers and passenger under carpet both dry. Checked connections and fuses, earths in footwell too.
This is the readout when scanned:-
Tuesday,18,January,2011,16:56:53:09663
VCDS Version: Release 10.6.3
Data version: 20101206
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8EX5A058553 Mileage: 73130km/45440miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC 0000SG 5934
Coding: 00002
Shop #: WSC 63351
VCID: 6AD011AC3CF9
WAUZZZ8EX5A058553 AUZ6Z0D0326259
2 Faults Found:
17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
P1586 - 35-10 - - - Intermittent
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-10 - - - Intermittent
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 4529
Coding: 04255
Shop #: WSC 06435
VCID: E5CAE29055E7
2 Faults Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AC
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 63351
VCID: 62C0798CC4C9
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 63351
VCID: 356AF2D025C7
4 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-00 - No Communications
79-00 - Please Check Fault Codes
00474 - Control Module for Immobilizer
01326 - Control Module for Multi-Function Steering Wheel (J453)
49-10 - No Communications - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: 3E78EDFC10F1
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 01011
Shop #: WSC 63351
VCID: 438E9C087B13
2 Faults Found:
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 M
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00401
Shop #: WSC 00762
VCID: 336ECCC82BB3
1 Fault Found:
00457 - Control Module for Network (J519)
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0704
Coding: 00001
Shop #: WSC 00000
VCID: EBDE94A8B303
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BD
Component: Komfortgerát TBF 1712
Coding: 06859
Shop #: WSC 63351
VCID: 74EC0FD46E3D
Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0205
Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0205
5 Faults Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
00532 - Supply Voltage B+
37-00 - Faulty
00466 - Control Module for Steering Column Electronics (J527)
01332 - Door Control Module; Passenger Side (J387)
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 M
Component: symphony II PM6 0410
Coding: 01201
Shop #: WSC 00512
VCID: 3162C6C0D1AF
Help would be appreciated as my hair is going fast!!!
69 75 76 77
Coding: 00002
Shop #: WSC 63351
VCID: 6AD011AC3CF9
2 Faults Found:
Coding: 04255
Shop #: WSC 06435
VCID: E5CAE29055E7
2 Faults Found:
P1857 - 35-00 - -
35-00 - -
Coding: 00000
Shop #: WSC 63351
VCID: 62C0798CC4C9
Coding: 00001
Shop #: WSC 63351
VCID: 356AF2D025C7
4 Faults Found:
Coding: 0010602
VCID: 3E78EDFC10F1
Coding: 01011
Shop #: WSC 63351
VCID: 438E9C087B13
2 Faults Found:
Coding: 00401
Shop #: WSC 00762
VCID: 336ECCC82BB3
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
VCID: EBDE94A8B303
Coding: 06859
Shop #: WSC 63351
VCID: 74EC0FD46E3D
Part No: 8E2959802B
Part No: 8E2959801B
5 Faults Found:
35-00 - -
35-00 - -
37-00 - Faulty
Coding: 01201
Shop #: WSC 00512
VCID: 3162C6C0D1AF
