Monster MotorsportVolks Autos
Results 1 to 7 of 7
    Dec 2010
    16
    Instrument cluster fault... easy to swap cluster? Any help welcome!
    Just getting to grips with my 2001 A4 2.5 Tdi. It has exhibited a huge array of odd faults over the short time I've had it. So far I have replaced all the ABS sensors, the battery, temp sensor, thermostat. Most of my gremlins have gone; all save 2.
    1. Fuel guage is erratic
    2. Temp gauge either works or doesn't read at all
    The themostat replacement was necessary as the engine now heats correctly. But the guage it would seem is also faulty.
    The car has already (by previous owner) been 'clocked' so preservation of the mileage recording isn't too important. Is it possible that this daft act has caused the problems?
    Can I simply buy a replacement instrument cluster and swap old for new or is there a more involved process?
    I did my best to search previous posts and have read about possible callibration and encryption issues. What do I need to be concerned about?
    Also... any ideas what a dealer would charge to do the job would be useful.
    Might be that it isn't the instrument cluster that is at fault but given the ABS light very occasionally goes on and off by itself I'd say it is on its way out. Perhaps I am overlooking something?
    Thanks for any advice.
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,713
    iv got a 2nd hand cluster if you want to try it? Im in Northampton, 10 min job to swap over,
    Jine's Avatar
    Crippled n Crazy
    Bristol
    86
    Dude, I'm sorry I can't shine any light on your situation but one thing I can say is that back last year I had a problem with the instrument panel on an a3, where one day not a single dial would work not even the MPH dial!! (it was murder trying to drive it). I took it to a specialist near me and had it replaced, it cost me 500 + labour. So god knows what the stealers will charge you.
    I feel your pain.
    A4 1.8T (190) S-LINE, Ebony black, Tints, Cream leather, RNS-E, 19" LM reps, Weitec Coilovers, RS4 ARB
    Next:- Remap, Exhaust, New wheels and some other bits n pieces
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    946
    The instrument cluster has the immobiliser built into to it so plugging in a replacement your car will not start!
    You need to recode keys with the new instrument cluster and code the instrument immobiliser with the Engine ECU - you will need the SKC code to do this I believe.
    Have you checked the connections to the Instrument Cluster and do any fault codes come up on VAG-COM?
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Dec 2010
    16
    I've been onto the dealer local to me. They want 612 to supply and fit the part. I asked if they would guarantee the work and to do that they want an additional 75 for a diagnostic that would tell me if everything was working the way it should. I assume that I would be able to drive away with everything working and there would be a reasonable guarantee against the work... only problem is I am not sure it is worth doing at that price?
    Thanks for the offer of the used part - but having researched it I think it needs to be programmed to match keys as mentioned and I am for an easy life so if I decide it is worth fixing then I might as well go to the dealer.
    Thanks for the help.
    Jine's Avatar
    Crippled n Crazy
    Bristol
    86
    Yeah the new cluster will definatley have to be coded to the keys for sure as it has the immobiliser on it.
    have you tried any specialists in your area?? the dealer should guarantee ANY kind of work they do on your car.
    Dec 2010
    16
    I'm near Newcastle - don't know of any Audi specialists. Might search the web but if someone can make a recommendation that would be great,
