Badger5JMB Retrofits
Results 1 to 15 of 15
    Dec 2010
    Lincolnshire, UK
    29
    Releasing a few horses from 1.8T 190
    Hi, ive got a B6 1.8T 190 and im interested in a silicone induction hose as all the ebay links say they help improve bhp, i can find plenty for lower spec 1.8T engines, are they all the same for the engines or would there be different ones for different hp models?
    Im only asking as there are some from china, that are very cheap (obviously the quality may show) and some from say Forge, that seem very expensive.
    Also, im interested in being able to hear a 'Dump/BOV' noise from my car when changing gear, will a basic aftermarket diverter valve achieve this? as i dont really want to buy an open air filter or Carbonio airbox, as i dont want to change the look under my engine bay.
    All advice/comments welcome
    Shaun
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,430
    the hose are the same for the 190 163 etc
    you need a forge split -r for the noise
    forge split r dump valve golf a3 1.8t VAG BOV vw audi on eBay (end time 22-Jan-11 20:19:54 GMT)
    Aug 2009
    833
    Check and rolling road your car first to make sure its in top condition, ive spent a good few quid getting my 190 to 190!!!
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Most of the silicon hoses on ebay are China specials and I wouldn't put one on my car. I do get the whoosh noise your after but I needed a Carbonio to get it right.
    If you have not already done it, remap your car - it's the best bang for bucks going.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,320
    Leave the chav-valve alone, it just screws up the fuelling. Its an Audi, not a Saxo.
    Reputable remap really is the best place to spend you money.
    TD5 Land Rover Defender build
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    I'd second the Rolling Road before you screw around with anything else - best 50 you can spend!
    "I" identified a failing fuel pressure regulator with a quick RR and released an extra 20bhp with a quick fix.... and that was on a NA car!!
    edit: Chip'N'Spin are doing their RR day on 26-FEB: 250 for a pre-RR, remap and post-RR. Hopefully they're stll doing this, but in the past, if they've found any probs (turbo probs, boost sensor / airflow meter problems, etc), they just charge you for their RR session and print outs (50).
    LostBok/BahnStormer77
    Dec 2010
    Lincolnshire, UK
    29
    Thanks for the advice everyone.
    Got in touch with a mate who knows someone with a rolling road, so hopefully will get it booked in asap.
    So you say any silicone induction hose from the 163 will fit my 190?
    Ill see about the re-map after the rolling road etc.
    On 10 days off now so im getting my windows tinted, blacking my grills, changing numberplate bulbs and possibly interior ones too.
    Shaun
    EDIT: Found this silicone induction hose on ebay, looks pretty reasonable, theres one for closer to 200, but it actually looks cheaper than the one pictured. I dont like the fact that its blue, is it possible to spray silicone black?
    AUDI A4 VW PASSAT B6 1.8T AIR INTAKE PIPE SILICONE on eBay (end time 21-Jan-11 10:49:52 GMT)
    Heres the 200 one, which one looks better?
    1.8T 20V Intake Kit 98-05 Audi A4 / Passat on eBay (end time 03-Feb-11 15:57:58 GMT)
    BahnStormer
    Feb 2009
    Surrey
    2,582
    make sure you get a RR session where the fuel mix is being measured, even better if it links into the OBDC and can tell u the boost level, etc.
    Aug 2009
    833
    i can tell you now my 190 is making 120 :D
    AU01 A4's Avatar
    Jan 2009
    Huddersfield
    211
    Quote Originally Posted by Nutkin View Post
    Come on, it cant have lost that much, have you remove the turbo
    Audi A4 1.8T quattro S Line Avant
    Aug 2009
    833
    Quote Originally Posted by AU01 A4 View Post
    I have no idea, goes into a garage for a week tomorrow.
    I had the DV cleaned (baileys) and the N75 changed still not boosting right. Turbo spools can hear it so your guess is as good as mine, just gonna check hoses for leaks tbh.
    AU01 A4's Avatar
    Jan 2009
    Huddersfield
    211
    could you have a leak in the intercooler or a connection to the intercooler, if you dont find any leaking pipe
    Dec 2010
    Lincolnshire, UK
    29
    I wouldnt have thought cleaning a dump calve with baileys would do any good
    Can anyone spread a light on the 2 above induction hoses? just curious as i have the money waiting
    Shaun
    Aug 2009
    833
    I personaly dont think it is worth it until you get the map and then i'd probably just grab the forge tip as its tried and tested. although gt3 turbo is a reputable site.
    AU01 A4's Avatar
    Jan 2009
    Huddersfield
    211
    The 190 have twin intercoolers, small ones behind the fog lights
