Sky InsuranceBadger5
Results 1 to 9 of 9
    pilcob's Avatar
    Jan 2011
    Southport, United Kingdom
    90
    RS4 vs S4 rear brakes
    What is the difference (if any) between the S4 B6 and the RS4 B7 rear callipers, I am aware of the actual disk differences.
    The reason I ask is my S4 has the RS4 front disks and callipers, but the rear callipers look like the original S4 items (not painted/powdercoated), I was told that a full front and rear conversion had been carried out when I bought the car.
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    just a thought, but are the rears both the same size?
    pilcob's Avatar
    Jan 2011
    90
    Quote Originally Posted by scott b View Post
    Same size as what?, S4 and RS4, sorry dont understand the question.
    scott b's Avatar
    1,254
    S4 and RS4 rears, are they the same size as each other?
    pilcob's Avatar
    Jan 2011
    90
    Dont know, thats what I am trying to find out, if S4 RS4 have same rear brake callipers.
    grum71's Avatar
    The S4 with the V8 soundtrack
    Oct 2009
    10
    If your car has the front RS4 conversion then you will need wheel spacers as the original Avus alloys won't fit over the calipers. That's one way to check. I have the Brembo upgrade and am limited to et30 offset with the alloys.
    The rear calipers ARE different...I cannot improve on this as I'm unsure of the exact sizes.
    Any clearer?
    Mar 2009
    182
    Can S4 brakes be fitted to any B6?
    As its a mod I'd like to do with having 320 discs up front
    Audi A4 1.9TDI Quattro Sport in Black - Turbo Dynamics Re-Worked Std Turbo, De-CAT, EGR mod, Remap, RS4 RARB, Koni FSD's and 320m DTM brakes up front.
    Factory fit - HID's (Osram CBI 5k bulbs), Bose, Comfort Pack, Folding Mirrors, Cruise.
    Mar 2009
    182
    Quote Originally Posted by QuottroA4 View Post
    Oh, and the engine from an S4 would be niiiiiiice too!
    pilcob's Avatar
    Jan 2011
    90
    Quote Originally Posted by grum71 View Post
    Any clearer?
    It defo has the RS4 front callipers and disks, calliper clearance between wheel is very tight.
    Just the rear I am not sure of, rear has standard vented disks not drilled or anything, and the callipers dont look that special.
